converter shudder
Old Feb 27, 2007 | 12:33 AM
scott's94z's Avatar
converter shudder
noticed somethig strange driving on the interstate a couple days ago. im cruising along about 65 and give it more throttle, about to the point where the converter unlocks. then i get this shuddder/pulsing that feels like the computer is trying to lock and unlock the converter very rapidly, a freequency of probably 5-10 times per second. more throttle and the converter unlocks completely, if i back off, it stays locked up. shudder only seems to happen when i roll on the throttle slowly. if i stab the gas, it unlocks cleanly. its an Edge street edge 3000 with only a few hundred miles on it, and a freshly rebuilt trans. any ideas of whats going on to cause this or is it supposed to behave like this?
Old Mar 1, 2007 | 12:01 AM
scott's94z's Avatar
does the computer pulse the unlock to make it smoother, but the extra surface area of the clutch over a stock converter make it more grabby and cause it to shudder?
any ideas?
Old Mar 1, 2007 | 12:40 AM
Performabuilt's Avatar
Supporting Vendor
a 94 should not have PWM there could be a presure problem or a lockup clutch
problem . 94s are a simple on or off operation .
Old Mar 1, 2007 | 06:32 AM
12SCNDZ's Avatar
Sounds like a converter clutch issue. I've seen quite a few clutch issues in Edge converters...Even in brand new converters.
Frank
CPT
Old Mar 1, 2007 | 07:53 AM
godspeed1976's Avatar
Frank
CPT
How is Fuddles Record? Do you see many issues with Fuddle Converters Frank?
Old Mar 1, 2007 | 12:10 PM
12SCNDZ's Avatar
Personally, no. All of our customers using Fuddle are happy with them.
Frank
CPT
Old Mar 1, 2007 | 07:40 PM
scott's94z's Avatar
is this something thats going to fail catastrophically and take out the transmission with it? or just minor annoyance? im not too sure of the severity of it.
Old Mar 1, 2007 | 08:42 PM
12SCNDZ's Avatar
With a shudder, you're probably seeing signs of the lock-up clutch burning up. You'll shed whatever debris from that into the transmission.
Frank
CPT
Old Mar 2, 2007 | 06:13 AM
Frank
CPT
Thanks for your incite Frank. I love a board that has vendors and true professionals in the community that will help you out. You do know now when I need a tranny I'm coming to you.
2QUIK6
Sep 17, 2016 02:31 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 7, 2015 08:52 AM
Aug 5, 2015 08:35 AM
detroitmuscle
Jul 31, 2015 04:21 AM
