clutches gone in my auto?
Old Jun 26, 2008 | 09:27 PM
wyldcdn's Avatar
problem just surfaced
Drive normal up to using 7/8's throttle everything fine. WOT car goes to shift at top of rpm, revs up to limiter like its in neutral. Started in only the 1-2 gear change, now does it 1-2, and 2-3 under heavy and WOT. Checked in with scan tool. Tranny temp never went over 234 degree. Both solenoids worked. Converter locked and unlocked. Side note, sometimes manually down shifting to 1st, it would't deacellerate. I have a 2800 stall, and it was hyper teched before i bought it for higher shift points. Tranny has 169,000, and was track raced til summer nearly every friday night. I just want to make sure I have covered all my bases before rebuilding
Old Jun 26, 2008 | 10:03 PM
Moshbmx1's Avatar
When that happened my opti went out...i assume it was related because after I changed the opti it stopped doing that
Old Jun 26, 2008 | 10:38 PM
Performabuilt's Avatar
Supporting Vendor
Sounds like your ready for a rebuild high clutch clearances etc
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
timmy39120
May 2, 2015 05:12 PM
blkWidow
Apr 21, 2015 01:56 PM
HectorM52
Jan 30, 2015 11:08 PM
