Clutch won't disengage all the way?????????
Old Jul 27, 2005 | 01:04 PM
  #16
arieso94Z28's Avatar
Re: Clutch won't disengage all the way?????????
Originally Posted by 96TurboTA
You can separate the slave cylinder from the master. I believe there's a roll pin you have to push out. Be sure to post up on how badly the disc is broken once you do get around to pulling the tranny.
Well just got done fixing it. It was the Slave Cylinder!.........I thought you said for SURE it was the transmission. There was a little plastic part that goes on the end of the slave cylinder that was making the noise. I'm glad I didn't drop the transmission!!!!! That would of been way more work. I appreciate all the great advice everyone!
Old Jul 27, 2005 | 06:12 PM
  #17
Josh'95Z28conv's Avatar
If it was the slave cylinder, the pedel feel would have gave it away right away. Thats why I talked about pedel feel in both of my posts.
Old Jul 28, 2005 | 08:03 AM
  #18
Well the pedel did feel fine. But it just wasn't disengaging all the way. I don't know. I am just glad its fixed.
Old Jul 28, 2005 | 11:17 AM
  #19
jsetzer's Avatar
The plastic cap is supposed to be on the end of the slave. And the side straps will be broke. Just in case you didn't know.
It comes new with it strapped down, you put it on the car like that and when you push the pedal a few times it snaps the straps on the side, the cap helps absorb vibrations and junk.
Heres why mine wasn't releasing.
Clutch
Old Jul 28, 2005 | 12:04 PM
  #20
96TurboTA's Avatar
Its very had to even put it into gear when the car is on, but when its off, I can go through the gears fine!.......
Based on this, what your claiming fixed it doesn't make sense. I don't believe you.
Old Jul 28, 2005 | 02:14 PM
  #21
hahaha........you don't believe me.........thats funny. What does the slave cylinder do? It pushins in the clutch fork to disengage the clutch. Now while the motor is on try putting it into gear without pushing in the clutch. Now turn the car off, and try it. You can go thru the gears while the engine if off without pushing in the clutch. The slave cylinder was completely broken. I could shake it and hear stuff rattling. I don't care if you don't believe me. The slave cylinder was the problem and now its fixed, thats all that matters to me.
Old Jul 28, 2005 | 02:26 PM
  #22
atf8611's Avatar
Glad to hear that you got it fixed. Its always best to start with the easy stuff first and rule that out.
sherwinZ28
11
Aug 15, 2015 05:38 PM
Jlo
Jul 29, 2015 03:52 PM
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
