clutch actuator
Old Aug 30, 2006 | 09:29 PM
96LT1TX's Avatar
clutch actuator
Well, the motor is about to run, I just snapped the clutch actuator thinking that it was installed right (forgot the bracket...doh). I was in a hurry and forgot to put that part in... does anyone have the part number for this? Or have an idea how much it will run? damn clutch actuator is made of plastic lol
cheap cheap plz be cheap cheap
Old Aug 31, 2006 | 08:30 AM
Re: clutch actuator
Do you mean you damaged the slave cylinder? The clutch fork is metal.
Old Aug 31, 2006 | 09:22 AM
96LT1TX's Avatar
Re: clutch actuator
I guess it is the slave cylinder, it is the plastic piece that pushes the clutch fork in. Whatever that part is
Old Aug 31, 2006 | 02:42 PM
OBE1 95Z28's Avatar
Re: clutch actuator
I purchased a slave cylinder from a local parts store for $72; part looked idential to the GM piece. Years ago I purchased an entire clutch hydraulic system (master, slave, reservoir, fluid installed) for $83 from Dal.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
