Cluch disc inner spring broke
Old Dec 21, 2004 | 01:43 AM
Johnnynsac's Avatar
One of my springs on my clutch disc came out/broke off. I only put about 4 thousand miles on the clutch, and pressure plate/complete clutch kit. Could I get away with just replacing the clutch disc with an aftermarket one instead of buying the whole clutch kit?
I don't know much about clutches but I'm learning.
Old Jan 4, 2005 | 04:43 PM
slp223's Avatar
Re: Cluch disc inner spring broke
whose clutch is it. old style spec have the problem alot. it happend to me spec sold me a disk at cost. $100
Old Jan 5, 2005 | 06:40 PM
Johnnynsac's Avatar
I bought the clutch kit from Napa Auto parts. My first clutch lasted me 70k so I thought it would be the same with this one. Guess not.
So your using your old pressure plate? How many miles did you have on the pressure plate and disk before it broke? I'm thinking of just buying the disk from spec or some other company if everything lines up and works correctly.
Do you have or feel any problems with yours?
Thanks SLP223
Old Jan 5, 2005 | 06:55 PM
slp223's Avatar
I broke the springs out of one spec sent me a new disk at cost i reused my pp but the i melted that clutch it could spec said it was only good to 700 tq at the flywheel so i did not last long. so i dont how long it would have lasted. also spec told me that transmission run out will affect the live of the clutch hub. I would recomend a stock gm clutch for any thing under around 375rwhp
Victor Lamb
Aug 26, 2017 02:52 PM
May 1, 2015 01:14 PM
BLK1997Z28
May 1, 2015 12:23 PM
R@mpage
Apr 20, 2015 10:02 AM
Nick's WS6
Aug 20, 2002 10:34 AM
