Car feels like someone is holding bumper
Old Jan 10, 2007 | 03:54 PM
mrmint69's Avatar
When i manual shift the car (a4) and you first let off the gas feels like someone it standing behind the car and holding on and then lets go all of a sudden. Only in 1st gear from a stop and let the car roll without giving it gas. If i accelerate it will move but with a slight hold back. If i leave it in first and do a couple start & stops it won't do it. In drive it has never happened so i can't figure this one out. Maybe something need adjusting.
Old Jan 10, 2007 | 04:46 PM
12SCNDZ's Avatar
Sounds like you've got a "tie up" somewhere. This is what it's called when a clutch is coming on/stuck on when it's not supposed to be.
Frank
CPT
Old Jan 10, 2007 | 06:47 PM
Performabuilt's Avatar
Supporting Vendor
Hi I'm not real sure I'm clear on what you saying but if you have the car in manual low and you give i throttle and let off you will have overun like a braking effect feeling like a drag down and that would be normal however there is no overun effect in the OD position right next to neutral ,
Old Jan 10, 2007 | 09:08 PM
mrmint69's Avatar
If i let off the brake the car will roll and move in drive. In low gear it is like the brake is on until i hit the gas. Once i move in low it is fine unless i shift out and go back to first.
Old Jan 11, 2007 | 01:07 AM
Supporting Vendor
you are describing a normal function all is ok there
see we are not like everyone else I dont want to sell you a transmission till you need it , sounds like normal overun to me
Jazsun
Dec 29, 2014 12:14 PM
CARiD
Dec 26, 2014 04:20 AM
heavenly_six
Dec 10, 2014 12:23 AM
USAirman93
Nov 24, 2014 03:37 PM
