tranny guys...
Old Jan 7, 2007 | 09:56 PM
Daniel6718's Avatar
tranny guys...
maybe frank, have you ever heard of first gear burnouts burning up a tranny? i mean is it really that much better to allow it to shift into 2nd then 3rd if it can?
Old Jan 8, 2007 | 12:16 PM
12SCNDZ's Avatar
We have customers doing it both ways without any failures. I, personally come off the line-loc in 2nd gear with my '93.
Frank
CPT
Old Jan 8, 2007 | 12:23 PM
Javier97Z28's Avatar
Moderator
I start at first and shift into 2nd.
Old Jan 8, 2007 | 12:42 PM
Performabuilt's Avatar
Supporting Vendor
I would see no reason why a first gear burn out would be any more damaging than any other gear wether manual or auto. In manual the forward clutch,overun clutch and the low reverse clutch are on which may help to support the sprags and roller clutches.and the auto first is the forward clutch with the low roller clutch holding but in either case these ae not generally considered trouble areas in the 4L60E and first is probably the strongest holding gear in the trans.
Old Jan 9, 2007 | 10:27 PM
Daniel6718's Avatar
ok thanks just wondering...i used to burnout in first and hold it about 5-6 seconds...you dont need to waste tire....
but now i just hit the gas and go 1-2-3 til the speedo goes to about 115 then roll out
Old Jan 11, 2007 | 01:09 AM
Supporting Vendor
You are fine dont worry
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
