B&M Deep Transmission pan?
Old Mar 31, 2004 | 08:04 PM
WS6Extreme's Avatar
Is it really worth spending $110 on a Deep Transmission pan for my 4l60E, or is it not worth it? Thanks ahead of time for the info.
Old Apr 1, 2004 | 08:28 AM
mongse_1's Avatar
The extra fluid capacity can't hurt. I'd make sure to get an aluminum pan rather than the chromed pans though. The chromed ones are el cheapo. Also make sure it's got a drain plug...sadly I've seen some that do not.
Old Apr 1, 2004 | 09:28 AM
WS6Extreme's Avatar
Thanks for the input !!
Old Apr 1, 2004 | 09:32 AM
rskrause's Avatar
Moderator
I wouldn't bother. A good cooler will do a lot more. I am running a stock GM pan on my TH400. Even with >800rwhp and a fairly loose converter (4,200 stall) it never gets above 180-190 degress with the B&M "Hi-Tek" cooler.
Rich Krause
Old Apr 1, 2004 | 10:08 AM
WS6Extreme's Avatar
what is the part number or exact name of that one?
Old Apr 1, 2004 | 10:44 AM
rskrause's Avatar
Moderator
I am using pn 70298 http://www.bmracing.com/products/acc...tekCooler.html
Rich
Old Apr 1, 2004 | 02:24 PM
WS6Extreme's Avatar
And that one is working great for you? Was it hrd to install, and how much should i expect to pay for that? Thanks for the info, and i am sorry that i am loaded with all kinds of questions.
Old Apr 1, 2004 | 02:55 PM
rskrause's Avatar
Moderator
Very easy to install because it doesn't need to be directly in the air stream (integral fan) and it's very compact. I think it was ~$170.
Rich
techstar
Aug 6, 2015 11:20 AM
whitehooptie
Jul 22, 2015 10:25 PM
94Form
Jul 17, 2015 10:56 PM
SergheiS
Jul 5, 2015 03:27 AM
