B&M Deep Transmission pan?
The extra fluid capacity can't hurt. I'd make sure to get an aluminum pan rather than the chromed pans though. The chromed ones are el cheapo. Also make sure it's got a drain plug...sadly I've seen some that do not.
I wouldn't bother. A good cooler will do a lot more. I am running a stock GM pan on my TH400. Even with >800rwhp and a fairly loose converter (4,200 stall) it never gets above 180-190 degress with the B&M "Hi-Tek" cooler.
Rich Krause
Rich Krause
Originally posted by WS6Extreme
what is the part number or exact name of that one?
Rich
And that one is working great for you? Was it hrd to install, and how much should i expect to pay for that? Thanks for the info, and i am sorry that i am loaded with all kinds of questions.
Rich
techstar
Aug 6, 2015 11:20 AM
Thanks ahead of time for the info.
