Any other options besides 12bolt/9inch?
Old Apr 12, 2006 | 01:07 PM
  #16
onebadponcho's Avatar
Re: Any other options besides 12bolt/9inch?
97FormulaWS-6, here's some reading for you:
http://www.f-body.org/tech/
Also, the Dana 44 rear end I mentioned was installed on the 1989 20th Anniversary Turbo Trans Am. You used to be able to order it through GMPP (part # 14044853) but I don't think it's available anymore.
One more thing, the Borg-Warner 9-bolt has a 7.75" ring gear.
Old Apr 12, 2006 | 02:04 PM
  #17
Originally Posted by 97FormulaWS-6
In 3rd gens??? uhm, I don't think so... That was the time of emissions choking everything; F-bodies didn't come with real HP numbers since the VERY early 70's, up to the 4th gens.
I have the torque and HP curves for the L98, LT1 and LS1, overlayed on one another. The L98 has more torque at low RPM than either the LT1 or LS1. Those long intake runners made great low end torque. The shorties in the LT1 shift some of the torque higher up in the RPM band. GM wouldn't install the T5 with the high HP L98's, because it couldn't handle the torque.
Old Apr 12, 2006 | 02:49 PM
  #18
97FormulaWS-6's Avatar
I stand corrected.
Old Apr 12, 2006 | 10:52 PM
  #19
bowtieman_racin's Avatar
noticed there are very few of those models hitting over 300ft lbs of torque. Dont know I've drove and owned quite a few 3rd gens and a gta is the fastest hardest pulling one I ever drove but my stock 94 z convertible still felt like it launched harder would turn the tires way easier and would just walk away from any of those cars. I had quite a few mods on my 91 z28 and never broke a rearend, but the fourth gens will tear them right out with sticky tires.
Old Apr 13, 2006 | 12:35 AM
  #20
revtime's Avatar
Yes its odd. My 88 IROC 350 would get with the program. relatively speaking, and I never had a rear problem.
Maybe I will try it just for grins and see what happens.
Old Apr 14, 2006 | 01:13 PM
  #21
95firehawk's Avatar
www.extremechassis.com
It's not much cheaper than the 9/12 but I would do this before trying to build up a stocker. Been there done that and didn't like it. lol.
Old Apr 14, 2006 | 04:32 PM
  #22
Originally Posted by 95firehawk
Hmmm.....where are they located?
Old Apr 14, 2006 | 07:49 PM
  #23
StudyTime's Avatar
Originally Posted by seawolf06
There is a way to fab up a 8.8 Ford rear, but you're prolly better off with a 12 bolt.
Hey, I take issue with that!
My 8.8" came out GREAT. It has the same diameter (strength) gearset as a 12-bolt, and it's lighter.
Check out my pictures. It looks much nicer in person. The pictures don't do it justice.
An 8.8" can be made 3 or 4-series ABS compatible and there are plenty of posi/gear choices available. They're also cheaper than a 12-bolt.
FWIW, a local guy's currently having an 8.8" built for his 140 mph trap Z28.
Ben T.
Ks0209
Oct 1, 2015 07:32 AM
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
