Any other options besides 12bolt/9inch?
Re: Any other options besides 12bolt/9inch?
97FormulaWS-6, here's some reading for you:
http://www.f-body.org/tech/
Also, the Dana 44 rear end I mentioned was installed on the 1989 20th Anniversary Turbo Trans Am. You used to be able to order it through GMPP (part # 14044853) but I don't think it's available anymore.
One more thing, the Borg-Warner 9-bolt has a 7.75" ring gear.
Originally Posted by 97FormulaWS-6
In 3rd gens??? uhm, I don't think so... That was the time of emissions choking everything; F-bodies didn't come with real HP numbers since the VERY early 70's, up to the 4th gens.
noticed there are very few of those models hitting over 300ft lbs of torque. Dont know I've drove and owned quite a few 3rd gens and a gta is the fastest hardest pulling one I ever drove but my stock 94 z convertible still felt like it launched harder would turn the tires way easier and would just walk away from any of those cars. I had quite a few mods on my 91 z28 and never broke a rearend, but the fourth gens will tear them right out with sticky tires.
Yes its odd. My 88 IROC 350 would get with the program. relatively speaking, and I never had a rear problem.
Maybe I will try it just for grins and see what happens.
www.extremechassis.com
It's not much cheaper than the 9/12 but I would do this before trying to build up a stocker. Been there done that and didn't like it. lol.
Originally Posted by seawolf06
There is a way to fab up a 8.8 Ford rear, but you're prolly better off with a 12 bolt.
My 8.8" came out GREAT. It has the same diameter (strength) gearset as a 12-bolt, and it's lighter.
Check out my pictures. It looks much nicer in person. The pictures don't do it justice.
An 8.8" can be made 3 or 4-series ABS compatible and there are plenty of posi/gear choices available. They're also cheaper than a 12-bolt.
FWIW, a local guy's currently having an 8.8" built for his 140 mph trap Z28.
Ben T.
NewsBot
Sep 30, 2015 04:20 PM
CARiD
Sep 30, 2015 05:44 AM
NewsBot
Sep 14, 2015 02:02 AM
