Aluminum Driveshaft?
Old Aug 28, 2005 | 02:16 PM
JDM-93_Z28's Avatar
Is an Ls1 aluminum driveshaft worth the money? What are the gains in replacing the stock one?
Old Aug 28, 2005 | 02:29 PM
slverbullet's Avatar
Re: Aluminum Driveshaft?
LOL, what are you expecting to gain? if your stock steel driveshaft is causing a lot of vibrations and you tried the 180* turn method to fix it, then i would probably buy an aluminum DS. thats provided your still making stock power or just a little more than stock.
if your looking for gains in power due to less rotational mass, then i would consider spending my money elsewhere for the time being.
Old Aug 28, 2005 | 03:52 PM
FutureZMan's Avatar
wight loss, and from my experiance a better over all balance.
Old Aug 28, 2005 | 06:55 PM
JDM-93_Z28's Avatar
yes i was told with the 5 pounds of rotating mass u will gain more power to the rear wheels....is it a noticable power gain?
Old Aug 28, 2005 | 07:12 PM
TruDualed95Z's Avatar
no, if it even shows up on the dyno
Old Aug 28, 2005 | 07:53 PM
LameRandomName's Avatar
There are a lot of good reasons to run an aftermarket driveshaft. Getting more HP to the tires isn't one of them.
I replaced MY driveshaft with a Dynotech MMC, but I did it because I was changing to stiffer gears and rebuilding my rear end anyway. Plus of course, I needed new U-Joints and the new driveshaft came with them. Basically, I did it because it was never going to be cheaper or more convenient than at that point.
Old Aug 28, 2005 | 07:55 PM
if youre going long term, check out a nice denny's ds.
Old Aug 28, 2005 | 08:59 PM
Kurt Crosbie's Avatar
I'm in the same boat. My u-joints are screwed and I need a new driveshaft. Why not get an aluminum one?
Old Aug 28, 2005 | 09:05 PM
MyShibbyZ28's Avatar
Well to answer the questions straight to the point.
Q:Why not get an alluminum one?
A:They don't hold up well if you want to mod your car, they work fine with stock engines but not for powerhouses.
Q:What gains are there?
A:about 1.1 rwhp. I saw a dyno sheet proving it once but can't find it, if i find it i'll post it.
Q: worth the money?
A: in my opinion, a total waste, 1.1 rwhp??? plus it doesn't handle as much as the steel one? totally not worth it.
ShibbyZ
Old Aug 28, 2005 | 10:26 PM
JDM-93_Z28's Avatar
thanks, ill make sure to save my money for sumthin else
Old Aug 28, 2005 | 10:35 PM
Welcome to CamaroZ28.com
Please post in the correct forum. "Driveshaft" questions don't belong on "LT1/LT4 Engine Tech". Moving to "Drivetrain".
The dyno test of the aluminum DS is on WS6.com.
Old Aug 29, 2005 | 10:50 AM
What is the 1LE driveshaft made out of?
Old Aug 29, 2005 | 01:17 PM
transamtom's Avatar
Here is the dyno sheet link:
http://www.ws6.com/mod-1.htm
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
