94 lt1 limp mode problem
Old Mar 2, 2010 | 04:44 PM
nuncio's Avatar
hi i dont know if im posting in the correct forum eneways i have a 94 chevy camaro with lt1 with few mods flomaster cold,air intake etc and my tranny is not down shifting or going into ovedrive every time i start the car i have first then i lose the gear once it shifts to second gear the trans never goes to first gear i already replace 4 sylenoids in the trans i also change filter and fluid i have search the web and found out my car is in limp mode please somebody help me p.s. could my opti spark do anything with limp mode?
Old Mar 2, 2010 | 05:23 PM
bw_hunter's Avatar
Tell us about the car, including all mods. The tell us if the check engine light is on and, if it is, what the codes are.
Old Mar 2, 2010 | 05:29 PM
nuncio's Avatar
is 94 camaro with lt1 almost stock i only have a`3inch exhaust and a cold air intake and i dont have my check engine light on
Old Mar 2, 2010 | 05:31 PM
bw_hunter's Avatar
OK, get the car scanned for any trouble codes (some don't light the check engine light). To tell the truth, it sounds like a tranny problem and not something that would involve all the sensors on the engine....
Old Mar 2, 2010 | 05:42 PM
nuncio's Avatar
well i already did that and theres no comunication with my computer well i been seaching on the web and found out my computer is in limp mode this is my second computer i replaced also i also put new selinoids in the trans and car still acts the same by the way i was looking under need the hood and saw 4th of july by the opti spark because theirs a crack were the coil goes to the cap of my optispark you think that has anything to do with the computer going to limp mode ????????
Old Mar 2, 2010 | 07:22 PM
nuncio's Avatar
94 z28 in limp mode
i have a 94 z28 and my computer is in limpmode the trans is not down shifting or up shifting by it self i only have 2nd and 3rd and reverse i have first went i first start the car but then the car feels slugish at take off i have to manually put in second gear to take off also it never goes on 4th gear plz someone help me is driving me nutsp.s would my opti spark have anything to do with the computer going to limp mode?????????
Old Mar 2, 2010 | 07:49 PM
nuncio's Avatar
Question 4l60e in limp mode
i have a 94 camaro z28 and my tranny has lost eletrical power i have change the selenoids in my trans and change twice the fluid and also filter.went i go to drive it it doesnt shift by it self or downshifts it feels sluggish at take off because ill take off in 3rd gear i have to manually put it in second i dont have over drive i have already spend alot money in this problem could somebody pls guide me in the rigth direction and i dont have my check engine light on etheir p.s would my opti spark have anything to do with it????????
Old Mar 2, 2010 | 08:02 PM
"Limp mode" is a condition that most people never experience. Its what the PCM does when it loses virtually all the critical data inputs. On the other hand, when certain codes set, the PCM will default to backup modes that keep the engine running, although maybe not at peak performance.
If your tranny isn't shifting, how did you come to the conclusion the PCM is in limp mode? Have you scanned it for codes? Is the SES light on? Are there any other systems that are not working, other than the trans?
Old Mar 2, 2010 | 08:12 PM
Wrong forum... and DO NOT CROSS-POST. You do not need to post the same problem in three separate forums. Post once, in the correct forum.
I'm going to attempt to merge these three post in a single thread on the Drivetrain forum. I'd much rather have spent the time trying to help you (already asked you some questions on the "General 67-02 F-Body Tech" forum), but I guess I'll have to spend the time merging threads.
Old Mar 2, 2010 | 09:54 PM
Unless you can communicate with the computer "limp mode" is a pure guess. Figure out your communication problem to diagnose and maybe get some real time scan data.
If your optispark cap is cracked, that is not a good thing no matter what else is going on. I would get that replaced.
Old Mar 5, 2010 | 05:27 PM
nuncio's Avatar
well i got my car scan with a obd1 scaner and the light flashes continusly for about 3minutes than it flashes for once for a second or two with a long pause i belive i have a obd2 system but i have a obd1 port shoud i rewired the port to a obd2 port ?????
Old Mar 5, 2010 | 09:51 PM
Your car is OBD-I and you cannot read flashes on the check engine light. A real code reader or scanner is required.
Old Mar 7, 2010 | 11:59 AM
nuncio's Avatar
o really so were could i get one of those scaners???????
Old Mar 7, 2010 | 06:53 PM
The are numerous outfits that make OBD-I scanners - AutoXray, Actron, Snap-On, OTC. Then there is free scanning software that allows you to scan and data log your PCM, including:
TTS DataMaster:
http://www.ttspowersystems.com/
FreeScan:
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
You will need a cable to connect a laptop to your ALDL connector:
http://www.akmcables.com/
Old Mar 23, 2010 | 08:23 PM
nuncio's Avatar
hey i scaned my car and they told me all my selenoids they were no good that i had to check them but i already replace them and today i check the old ones and their good i check them with a 12volt battery and they click so a mechanic told me that theirs maybe a bad ground on the trans so my question is were should i look for the ground on this trans ?????????
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
1LEThumper
Jul 14, 2003 12:45 PM
JSK333
Sep 9, 2002 10:33 PM
