84 10 bolt to a 94
Old Jun 5, 2005 | 02:41 PM
FryedClutch's Avatar
84 10 bolt to a 94
im in need of a new rear and i found a 10 bolt from an 84 fbod will that just bolt right up to my 94 if not what needs to be changed
Old Jun 5, 2005 | 03:25 PM
Z95m6's Avatar
Re: 84 10 bolt to a 94
I believe the 3rd gen rear is several inches narrower than the 4th gen or its the other way around. I believe it will work but you will need some wheel spacers.
Old Jun 5, 2005 | 08:20 PM
saxmo's Avatar
I have a Eaton 3.08 posi from my 1984 truck.. will it fit in my 94 Z28?
Old Jun 5, 2005 | 09:26 PM
im perty sure the pumpkin will fit in
but i was curious abaout the entire axle housing
Old Jun 5, 2005 | 10:52 PM
The 3rd Gen and 4th Gen 10-bolts are identical, except for the width, and the brake plates. The shock, spring, TA, panhard rod, etc. connections are identical. But, at least according to the drawings on the Strange website, the 3rd Gen rear is 3" narrower than the 4th Gen. Wheels that fit a 4th Gen will have too much offset/backspace with a 3rd Gen rear axle assembly. You will need 1.5 - 2.0" bolt-on spacers for the rear wheels.
Old Jun 6, 2005 | 09:23 PM
mw's Avatar
mw
And it won't have the sensor or ring for the abs.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
