700r4 question
Old Jan 29, 2007 | 06:49 PM
Geoffmj's Avatar
700r4 question
Just wondering will a 700r4 from an 87' Suburban 4x4 swap into an 85 z28 w/700r4? If so what will i need to change. Thanks for the help.
Geoff
Old Jan 29, 2007 | 06:59 PM
Pete Kane's Avatar
To make a 4wd trans work, you will need to swap the output shaft, output housing, speedo gears, speedo sensor and the governor(while you are there)
Old Jan 29, 2007 | 07:20 PM
12SCNDZ's Avatar
The swap listed above requires that the transmission be pretty much completely disassembled.
Frank
CPT
Old Jan 29, 2007 | 07:22 PM
Geoffmj's Avatar
Not worth it? thanks for the replies
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
