4l60e Trans Fluid and capacity.
Old Oct 24, 2005 | 06:58 PM
94 TEALBIRD's Avatar
What kind of fluid does it take? And how many quarts?
Old Oct 24, 2005 | 10:55 PM
Re: 4l60e Trans Fluid and capacity.
PLEASE post on the correct forum..... "4L60E" topics do not belong on "LT1/LT4 Engine Tech". Moving to "Drivetrain".....
Old Oct 25, 2005 | 07:54 AM
LWillmann's Avatar
Stock converter, if the system is totally dry (nothing in the converter or trans or cooler, I believe it takes 11 quarts.
With my Edge 9.5" converter, dry trans and coolers, it took 10.5.
With just a fluid swap (dropping the pan, changing the filter and putting back together), It's right at 5 quarts I believe.
EDIT: The other question, what kind of fluid... Dexron III Mercon ATF.
Old Nov 11, 2005 | 06:41 PM
jakesnake123957's Avatar
Dexron 3
Old Nov 11, 2005 | 07:48 PM
12SCNDZ's Avatar
Dexron III / Mercon. 13 quarts is about right for a stock 12" converter. We use either Valvoline or NAPA brand in our rebuilds. Make sure you don't use any type of additives.
Yes, a simple fluid / filter change will take around 5 quarts.
Frank
PCLZ28
Dec 24, 2015 05:19 PM
blac94Z
Jul 5, 2015 09:48 AM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
Chris 96 WS6
33
Sep 3, 2002 09:48 PM
