4L60E Delayed 1-2 Shift
The shift from 1st to 2nd gear in my 4L60E is delayed. Under normal driving it shifts late and shifts hard. Under WOT, it will hit the rev limiter because the shift is delayed. I need to scan for transmission codes. Any suggestions on what to check or where to start?
Re: 4L60E Delayed 1-2 Shift
It is a 1994 with 140k miles.
I replaced the shift solenoids and 1-2 shift accumulator. The previous owner had disabled the 1-2 accumulator. They had the piston upside down and washers & nuts in place of the springs.
It improved part throttle shifts but haven't tested WOT shifts.
It's hard telling what has been done to the tranny. I saw Transgo stamped on the separator plate.
I forgot to ask if your engine light was on
If you have codes you can access them without a scanner
http://www.obd-codes.com/faq/read-gm...codes-free.php
Additionally, some of the trans codes don't turn on the SES light.
KamaroL98
Oct 22, 2002 02:58 PM
onebad97z
Jun 27, 2002 09:28 AM
