Setting REV. Limiter higher???
Old Jul 2, 2002 | 12:20 AM
U2Slow's Avatar
Question Setting REV. Limiter higher???
I used hpp3 and adjusted my rev. lim. at 6200.. Will I hurt anything if I move it up to 6400? That should help some performance, right? maybe a bit>
I didnt mess with shift points yet.
thanks
Sasa P.
12's 98Trans Am
3.73 gears, vig3200, lid, cutout
Old Jul 2, 2002 | 08:46 AM
asianice25's Avatar
Cool
You can raise the rev limiter to 6500rpm with a stick . i wouldn't go too much higher than that, because the valve train was designed to be good to 6600. My neighbor designed part of the ls-1 and ls-6. he now works on the northstars. Itll pull all the way to 6500, i know. i raised mine, but the tach only shows about 6300 when its supposed to be 6500???
Scott Parkinson
2001 Sunset Orange Z-28
SLP Loud Mouth, K&N, Mass Air, 160 Thermistat, Power Programmer, All aftermarket suspension/braces, 8.5mm Plug Wires, 125 hp Shot. Runnin low 12's all day.
Old Jul 2, 2002 | 01:17 PM
supersp0rt's Avatar
Post
i think youll be ok at 6400, but you arent going to be making anymore power than you would be at 6200.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old Jul 2, 2002 | 04:17 PM
Bull_in_a_china_shop's Avatar
Post
Search for rev limiter her and ls1.com I'd say leave it. You're not making any more power. See what the searches net you
Old Jul 2, 2002 | 07:05 PM
PhantomTA's Avatar
Moderator
Post
Shift at 6000. any higher with stock ca and springs is a waste of time and a chance to hurt something.
your car makes less and less power after 6000
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Jul 2, 2002 | 10:23 PM
U2Slow's Avatar
Post
Thanks guys, I see that there is some difference in opinion.
I will go search for rev limiter in Search now. hopefully i can find something interesting.
So, by raising rev. limiter, it doesnt help anything in automatic????
Sasa
Old Jul 2, 2002 | 10:24 PM
GatotsuZeroshiki's Avatar
Post
If you didn't adjust the shift points on your auto then it'll just shift way before the set redline, even at WOT, so unless you're in OD, it's basically useless.
Old Jul 3, 2002 | 01:58 AM
U2Slow's Avatar
Post
this my set up..
98TA A4 with 3.73s and Vig 3200
What kind of shift points should i set up..anyone have similar set up..
WOuld like to keep rev.limiter between 6200-6400..
maybe something like this...
1-2 shift, I think it is fine, maybe +1
2-3 shift, i would like to go +4 (when i raced my budy, he gets me in this shift, but then on 3-4 i get him back)
3-4 shift, maybe +1 or +2...
what do you all think about that???
(i will have to give it a try and see)!
thanks
Old Jul 3, 2002 | 09:37 AM
rncotton's Avatar
Post
The only way to truly set your shift points is at the track or on a Mustang Dyno.
First, you have to be able to run the same 60' time over and over and over. Once you are sure your launches are all the same, start working on the 1-2 shift. You should see a better result in your #'s. Keep bumping the 1-2 shift up by 1 MPH on each run until you see a DECREASE in numbers, then go back 1 MPH.
Now work on the 2-3 shift ... do the same thing. Increase 1 MPH per run until you see the numbers start to back off.
There ya go ... may be hard to get it all done in one night unless there is light traffic at the track and you can get in several runs.
You might work on the 1-2 shift point one night and then work the 2-3 the next time.
Now, if you can find someone with a Mustang Dyno, then you can do it there. It gives you a decent estimate of your 1/4 mile time and your 60' times should be identical on each run since you won't have to worry about wheelspin off the line. (remember, your chassis is strapped down onto the drums)
You should be able to dial it in within 6 - 8 runs at the most.
Track = cheaper, but harder due to having to run IDENTICAL 60' times. If your 60' times don't match, you have to toss that run.
Mustang Dyno = quicker and easier, but having to spend $$$ for the dyno time. Remember also that you'll have to spend 10 minutes between runs while you reprogram the computer with the new shift points.
Good luck !
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80
2001 Z28
-- R.I.P. - 06/25/02
Old Jul 3, 2002 | 02:31 PM
U2Slow's Avatar
Post
thanks a lot bro.
I will try to mess with it some how..
thanks again'
DirtyDaveW
Dec 1, 2016 05:37 PM
carl.froehlich
Mar 13, 2015 12:38 AM
blac94Z
15
Mar 2, 2015 12:00 PM
Jan 23, 2015 01:13 PM
Nostang 96z
Sep 10, 2002 08:54 PM
