4L60 in 94' Z28.
Old Apr 12, 2009 | 01:21 PM
sandman63's Avatar
4L60 in 94' Z28.
What would it take to put a 4L60 in my 94 Z28, is it possible? The reason i ask is my trans is leaking pretty bad, fluids burnt and its starting to slip and there's a built 4L60 for sale locally for a pretty decent price.
Thanks.
Old Apr 12, 2009 | 09:14 PM
12SCNDZ's Avatar
You'd need a TV cable from a '93 F-Body, a '93 LT1 throttle body that has a pivot ball for the TV cable, a '93 TV cable bracket that bolt to the throttle body, and most likely, a '93 F-Body governor to get the shift points right. You'll also have to make certain the 4L60 (700) is out of an F-Body, otherwise you'll have to change the tailhousing. You'll also have to pull some lock-up wires out of your wiring harness to run to the case connector on the 700.
Frank
CPT
Old Apr 12, 2009 | 09:54 PM
sandman63's Avatar
Frank
CPT
Well that's alot more work than im willing to do to get this trans to work, thanks Frank!
Old Apr 14, 2009 | 07:31 AM
CrashnBurn's Avatar
my answer is much simpler....buy a built 4l60e from frank
marlar98
Sep 12, 2018 07:18 AM
football4life
Oct 4, 2015 07:48 AM
marlar98
Sep 19, 2015 07:53 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
maverickmk
Sep 1, 2015 09:17 PM
