4L60 in 94' Z28.
4L60 in 94' Z28.
What would it take to put a 4L60 in my 94 Z28, is it possible? The reason i ask is my trans is leaking pretty bad, fluids burnt and its starting to slip and there's a built 4L60 for sale locally for a pretty decent price.
Thanks.
Thanks.
You'd need a TV cable from a '93 F-Body, a '93 LT1 throttle body that has a pivot ball for the TV cable, a '93 TV cable bracket that bolt to the throttle body, and most likely, a '93 F-Body governor to get the shift points right. You'll also have to make certain the 4L60 (700) is out of an F-Body, otherwise you'll have to change the tailhousing. You'll also have to pull some lock-up wires out of your wiring harness to run to the case connector on the 700.
Frank
CPT
Frank
CPT
Frank
CPT
Frank
CPT
