3000+ stall not working on lt1??
Old Dec 3, 2004 | 04:49 PM
Myxtreme1's Avatar
Ok, I called a particular vendor to get info on one of their stall converters and when I told them I had a '94 lt1 they said that there was a particular year LT1 that there was no way to get the computer to be able to work more than a 2800 stall converter. I don't see how this is true bacause I have and will have Madwolf's programming, not to mention with my cam and motor I will need a converter larger than a 2800 IMO.
Old Dec 3, 2004 | 05:00 PM
1SlowFormula's Avatar
Re: 3000+ stall not working on lt1??
look around for things about stall wall or limp home mode. There are fixes out there but I think madwolf just says to fix it you need to go with an ODBII PCM.There are other tuners out there with fixes or work-arounds!
Old Dec 3, 2004 | 05:10 PM
Myxtreme1's Avatar
Just doesn't sound right to me. What did you do for your 3500?
Old Dec 3, 2004 | 05:41 PM
rskrause's Avatar
Moderator
If you do a search you will find extensive discussion here of the problem with an OBDI computer and a converter with a stall speed >2,800 rpm.
Rich
Old Dec 4, 2004 | 09:28 AM
timelord's Avatar
Ed Wright,only 2 words you need!!
Old Dec 4, 2004 | 09:48 AM
Myxtreme1's Avatar
Who is he?
Old Dec 5, 2004 | 08:21 AM
n2oCamaro's Avatar
Bryan at PCMforless also has the fix. Not to mention cheaper and no locked PCM.
"Who is he?"
Ed is a programmer/tuner.
Old Dec 5, 2004 | 10:17 AM
timelord's Avatar
I think he doesn't lock them anymore,at least not as tight !!
Old Dec 5, 2004 | 11:45 AM
Myxtreme1's Avatar
So I guess Madwolf would have this fix as well? I am still waiting to hear from him.
Old Dec 5, 2004 | 09:15 PM
Loadre's Avatar
The OBD-I high stall problem usually only occurs when you cut a hard 60' anyway. For street driving there are usually no worries.
Old Dec 6, 2004 | 11:04 AM
Not really mine did it with a 2.03 60' but yes it only happens at the track and there are different versions of the problem out there.
I wiped out my PCM trying to fix it myself, and had to send the PCM out to get the flash chip replaced, because I corrupted mine. I sent it to Bryan @ PCMFORLESS, and he is going have the chip replaced and load his fix for me. I should be getting it back soon. He just emailed me that it was done!
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
