273 to 323 gears
Old Mar 23, 2009 | 08:40 AM
Tanner_94_Z28's Avatar
273 to 323 gears
ok i learned since my car doesn't have the 1st gear in my shifter that it has 273 gears and i found a T/A that should have 323 gears...so i was wondering if i did a swap would i notice a big difference in the cars speed and power?
Old Mar 23, 2009 | 11:13 AM
n2ceptor's Avatar
Not alot..... A little bit quicker off the line... I would suggest 3.42s for a daily driver...
This is an automatic??
Old Mar 23, 2009 | 11:18 AM
yes an automatic.... i have 94 camaro camaro z28...stock and i spun a bearing and i am pulling a motor out of a T/A so i was gonna take the rear end out too...it has the first gear so i figure it has the 323 gears...
Old Mar 23, 2009 | 05:35 PM
1996camaroSSclone's Avatar
I did that swap and wished I would have went to 3.42s
Old Mar 24, 2009 | 08:12 AM
for as much as i'm paying for the rear end i looked up and i could by 373 gears for the same price....so i think ill just do that...
Old Mar 24, 2009 | 12:40 PM
n2ceptor's Avatar
Check the glove box of the TA... Codes for rearend..
GU2 = 2.73
GU5 = 3.23
GU6 = 3.42
For an auto, daily driver, I suggest 3.42.... If a weekend warrior, then 3.73.. I use 3.42, because is less wear on the engine, trans, rearend, etc. at highway speeds...
Old Mar 24, 2009 | 08:34 PM
GU5 = 3.23
GU6 = 3.42
http://www.ws6.com/faq/4_3.htm#ch4_3a
Old Mar 30, 2009 | 05:54 PM
williamfvc's Avatar
GU2 = 2.73
GU6 = 3.42
Hi n2ceptor, I have a 94 z28 with a 2.73 and i recently buy a 3.42. What i need to install the 3.42?
Old Apr 7, 2009 | 06:07 PM
it's allgood's Avatar
You can cut the plastic stop off at the shifter to get into 1st gear. If you have not already. I cut mine off with a hack saw, it took 30 seconds.
I heard 93-94 F bodys had the 1st gear lock out, for some reason. Like noise or?
Old Apr 8, 2009 | 08:10 AM
PoorMan's Avatar
I would wait and find a 3.42 rear. I did the swap 2.73 to 3.42 when my car was an auto. Perfect for a DD.
BLK1997Z28
May 7, 2015 03:01 PM
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
ZZed
Sep 10, 2002 04:13 PM
