1993 T-56 swap
Old May 4, 2005 | 08:01 PM
resurrectedz28's Avatar
1993 T-56 swap
I was wondering if there were differences when swapping a T56 into a 1993 camaro, as opposed to 94-97, I know there are differences unique to the 1993year, and most of the writeups Ive seen for the swap were for 94-97cars, and most of the searches Ive done on here showed most of the cars were 94-97. Anyone know? Thanks.
Old May 4, 2005 | 10:22 PM
stroked 93z's Avatar
Re: 1993 T-56 swap
it is the same, i also have a 93 and used instructions from the internet. the reason i believe you cant find directions for a 93 is because the camaro didnt come with a t56 until 94
Old May 5, 2005 | 09:55 AM
Re: 1993 T-56 swap
As far as I know, the Borg-Warner T56 was used in the 93 models. There were several differences though, including the absence of the "skip shift" solenoid, the operation/output of the VSS, and the gear ratios. In fact there were two different T56 options for that year... M28 (3.36 1st gear) and the M29 (2.97 1st gear), as opposed to the 94 and later versions, with the 2.66 1st gear ratio.
There would be no difference in the A4->M6 swap procedure, except that you don't have to wire up the skip shift solenoid (or bypass it as most people do).
Old May 5, 2005 | 12:54 PM
Re: 1993 T-56 swap
alrighty, thanks for the info.
Henson071
Dec 30, 2015 09:55 PM
smoknta
Aug 27, 2015 05:07 PM
gtstriker86
Aug 26, 2015 10:56 PM
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 24, 2015 10:47 AM
