12 bolt question, different than most...
Old Apr 23, 2004 | 06:36 PM
snksknr94's Avatar
I've had the abs diconnected on my car for several years now. It needs a new abs module, but the module is about 400 bucks and involves pulling most of the dash out to gain access to it. Well, now I need a 12 bolt, but if I get one without the abs provisions I will save quite a bit of cash, since my abs isn't connected anyways, and I have no plans on dropping the cash to replace that module anytime soon, should I just get the 12 bolt with no abs provisions? Can they be added at a later date, say if I decide to replace the module and have abs again? I need to order the 12 bolt pretty soon to get the car rolling again, but cash flow has dwindled a bit lately so any amount I can save on this would be awesome.
Old Apr 23, 2004 | 06:46 PM
97FormulaWS-6's Avatar
I don't believe it can be added later unless it's a 3ch system with the sensor in the pumpkin, and even then only if it's done the way it's done with a 9" rear. (With the 27-tooth geat welded to the DS.)
If you're talking the Moser or Strange 12-bolt, they cast in the required casting for the sensor, and I also believe the inside of the pumpkin has to be larger due to the reluctor ring that goes on the Ring Gear.
Old Apr 23, 2004 | 06:52 PM
Pasky's Avatar
I'd go without ABS. If you know how to drive your car you don't need ABS.
Old Apr 23, 2004 | 07:08 PM
snksknr94's Avatar
Basically I guess I just need to know if I go without the abs provisions do I need to do anything else other than not plug in the existing sensors in the rear, since they'll have no place to go.
Old Apr 23, 2004 | 08:14 PM
LameRandomName's Avatar
Not an answer to your ABS question, but if you have to replace your 10-bolt, you may want to give serious consideration to going straight to a ford 9-inch.
Not because of the strength, but because of the drop-out center section allowing fairly easy gear swaps.
Old Apr 28, 2004 | 12:53 PM
snksknr94's Avatar
Anybody have any idea about this?
Old Apr 28, 2004 | 10:06 PM
snksknr94's Avatar
I tried calling Strange today about this but nobody answered the phone the 3 times I called.
Old Apr 29, 2004 | 06:19 AM
Just leave tie it up, you will have no problems.... but I hope you don't even plan on putting it back into the car... the pumpkin won't have the provision for the sensor.
Old Apr 29, 2004 | 03:46 PM
snksknr94's Avatar
Sweet, thats all I was worried about. I won't be putting the abs back in.
Sergio
Jan 27, 2016 04:27 PM
maybe2fast
Mar 16, 2015 09:45 AM
mikey4play
Mar 15, 2015 11:45 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
