12 bolt = junk
Old Sep 1, 2003 | 11:27 AM
  #16
526 SS 96's Avatar
Joe and RSkrause hit the nail on the head I have basicly the same set up they do: Moser 12 bolt, 33 spline axles, eaton posi, 4:56's, c-clip elim, aluminum cover, BMR track pack & subframes, Hoosier 26 x 10's drag W/ matching skinnies, QA1's and air bags. Best 60': 1.51. I had the same problem with the bolts comming loose , but I solved it with lock tight red and an impact gun.
Not to get off the topic, but I just wanted to say that there is nothing sweeter that pulling the wheels 8-12" off the ground from a 20 mph roll. I absolutly love my drive train.
Old Sep 1, 2003 | 03:05 PM
  #17
JordonMusser's Avatar
West South Central Moderator / Special Guest
uh.. next time you should not let the bolts back out i use red loctite and lock washers..
for the orig poster-
nothing is bullet proof. I have broken my 12bolt a couple of times over the years, but then again.. I am hard on parts. And as RIch said, if you broke the posi.. it doesn't matter whether it was a 9" or a 12bolt.
I see a lot of people dont take up slack in there driveline, and other "rear end danger" things at the track.
Hell, i went 1.7s-1.8s and mid 11s ona stock rear with out problems.. just gotta drive it as rear end friend as you can..
(note, rear end friendly doesnt mean not hard.. I launched my 401 ci motor off the rev limiter just about)
Old Sep 1, 2003 | 03:19 PM
  #18
Josh'95Z28conv's Avatar
Personally, I think you should go with the 9". And then send the 12 bolt to me
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
