budget rear - options?
Old May 11, 2008 | 08:02 PM
Mtxz453's Avatar
I just put 4.10's in my 10-bolt and a girdle but am afraid it won't hold once i do a cam and nitrous. I also wanna be able to launch at the track without blowing the rear apart.I know there isn't anything else I can do to the stock rear to make it handle 5k dumps with a cam. I don't have 2500 to dish out for a rear and wanna know if anyone has taken rears out of other vehicles that would withstand the abuse. I was thinking maybe something along the Dana rears might hold but haven't heard anyone doing it or how hard they would be to fit under an f-body.
Old May 11, 2008 | 09:21 PM
si's Avatar
si
I just spent half the day reading on rears on 3 different fourms. For that kind of power you are going to need a bigger rear 9" or 12" (been their done that)
Old May 11, 2008 | 09:40 PM
Mtxz453's Avatar
damn.. i kinda figued that but can you pull a dana 60 out of a junkyard that was on an older truck and bolt it up to my camaro or am i limited to a new ford 9 inch or moser 12 inch in order for it to bolt up to my car and work properly
Old May 12, 2008 | 12:23 PM
z28 justin's Avatar
You can pull an old Dana or even a 12-bolt or 9inch, however you'll then have to weld in all the mounting brackets and resize the axles and tubes to fit under your car. Not an easy task
Old May 13, 2008 | 09:06 PM
LJM97Z's Avatar
My advice, i am in the same boat as you, so i came to the decision that the BEST $$$ is going to be spent on a better/stronger rear & **** can the 10 bolt, SO, i went & made payments on a 9" Moser houseing/axle package from EPP, it'll come with caliper spacers/studs & norrowed if wanted for 1000.00 to the door, i was going to get a 3rd. member from a junkyard, then was told why put a 30 yr. old case thats weak into such a good assembly, i looked on e-bay & found NEW Strange "N" nodular 3rd. member cases for 230.00, so when all said & done, i'll be out about 1600.00 for all the parts needed, houseing/axles/bearings/studs/ drag spool/ring & pinion/pinion support, this set up will handle an EASY 600+ rwhp at all times with a good D shaft & loop, i'll only be putting 290rwhp most of the time, so in my case, the skies the limit on how low i can get the ETs with stickies & NO worries EVER out of the rear, then i'll spray 100 shot every now & then.
I decided i don't like going to the track & biteing all my nails off before each pass worring if i'll make it home, everytime i've been at the track this past month, i've seen at least 1 F body grenade there 10, most had street tires & bolt-ons only, its just a 50/50 chance i'm NOT willing to take, i love this car & it hails ***, so i won't to have fun in it, i am just as broke as you, just put EVERY dime you have untill you get a better rear, you'll be glad you did.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
pimpss96
Feb 12, 2015 01:28 PM
InfernalVortex
Jan 17, 2015 09:35 AM
ddr698
Jan 9, 2015 10:05 AM
rockync7
Jan 1, 2015 05:10 AM
