Trouble launching after 9" install
Old Jul 18, 2004 | 01:24 PM
KENS96M6's Avatar
I would like to hear from others that had trouble launching their car after installing a Moser 9". I cant cut anything better than a 1.9X 60ft. with E/T streets. Suspension is stock except for lower control arms,relocation brackets, and air bag. The car is an LT-1, M6 with hot cam, intake, exhaust, street twin, 150 shot N2O, and 4.10 gears. Thanks, Ken
Old Jul 18, 2004 | 03:31 PM
Black95Form's Avatar
What is your tire pressure? What rpm are you launching at? I have a 12 bolt and I am leaving at 5500 rpm. You should be able to do better.
Michael
Old Jul 18, 2004 | 07:51 PM
zupmanZ28's Avatar
Re: Trouble launching after 9" install
Are you getting a lot of wheelhop? I never got any wheel hop with the 10 bolt, but as soon as i installed the 9" the wheel hop went through the roof, which i would assume is because of the all the extra weight. I'm told that the fix for this is relocation brackets and or airbags in the rear springs.
Hope that helps a little.
Eric
Old Jul 18, 2004 | 08:55 PM
KENS96M6's Avatar
Thanks for the replys. I have tried tire pressures down to 16psi but the car got real loose at the end of the track at that low. I can not leave at anywhere near that high an RPM. 3000 is as high as I have left. I had real bad wheel hop before the lower control arms and air bag. They solved the wheel hop but I still cant hook like I think I should.
Old Jul 18, 2004 | 09:31 PM
Man that seems like alot of air in the rears, I run anywhere from 10.5 to 13 pounds in my hoosiers depending on what the track is doing. You may want to check your pinion angle. If you are using a stock torque arm that will definitely be your problem. I think the torque arm provision for the moser 9 inch will change the pinion angle. Your pinion angle should be somewhere around 1 to 3 degrees negative.
Michael
Old Jul 19, 2004 | 08:47 AM
GREGG 97Z's Avatar
I'm curious about this too. I installed a Moser 9" recently with a mainly stock suspension. Just on the street the car felt loose in the backend when I took it out after the install, I havnt even taken it to the track yet. I have heavy duty Metco lca's, lca brackets, and I just added a BMR adjustable phr. That helped with the side to side alignment and stiffened things up a bit. Everything else is stock except some new ES bushings. I really want to get a body mounted adjustable torque arm to stiffen things up more and to correct the pinion angle. Not to mention I need a new clutch too
Old Jul 19, 2004 | 10:45 AM
Have you checked the pinion angle? Appears both the people with problems are using the stock torque arm. The 9-inch drops the centerline of the pinion shaft about 0.75" compared to a 10- or 12-bolt. You need to reset the pinion angle. The 9-inch also typically moves the TA mount point to one side (I think its the drivers side) so that may also contribute to traction problems.
Just a thought.
I'll agree with the tire pressures.... I think I started at 16psi with the QTP's and came down to 12psi. But, just to be clear, I run the 12-bolt.
Old Jul 19, 2004 | 07:35 PM
KENS96M6's Avatar
Thanks, everyone. I checked the penion angle and thought it was ok, but I probably messed up. I will go back and check it again. It looks like time for a new TA. Thanks again
Old Jul 22, 2004 | 11:05 AM
Serene's Avatar
What did you figure out on the 9" plus stock torque arm regarding the pinion angle? What was your angle?
Old Aug 16, 2004 | 03:36 PM
Serene's Avatar
ttt
Old Aug 16, 2004 | 07:30 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
yea, check your pinion angle.. but 16psi is a LOT. i run from 10.5-13 or so..
and YES, its gonna feel really crappy on the top end :-D
Old Aug 16, 2004 | 08:12 PM
ABA383's Avatar
I just had a similar discussion with Gordon Spohn. The 9" center is slightly offset and not centered under the car like the 10/12 bolts are. In fact, their TA has two mounting positions to compensate for this problem. Using a stock TA may bind the suspension by not being lined up correctly behind the transmission. Even if pinion angle is right you may still have alignment problems. Just a thought. By the way I just installed one of Spohns TAs...Truely a beefy, awesome piece...
--Alan
Old Aug 17, 2004 | 09:03 AM
rskrause's Avatar
Moderator
What is it doing when you launch? Spinning, bogging? How does the car react? Does it squat, stay level, or does the rear lift? Etc., etc. A slo-mo video of the launch is a big help, especially if you mark the rear tires with a paint strip so you can see if they are spinning or hooking. What were your 60' before the 9" was installed?
Rich
Old Aug 17, 2004 | 10:28 AM
GREGG 97Z's Avatar
--Alan
Thats interesting, I didnt know that. I have a Moser 9" that I installed in mine a few months ago and I tried using the stock TA at first. It was a pita to try and reinstall the stocker, it seemed like it didnt fit right and the car felt 'loose' to me in the backend when getting on it. I was looking at replacing it with an aftermarket adjustable one, I think I will go with the Spohn after hearing this.
Old Aug 17, 2004 | 07:46 PM
ABA383's Avatar
I still run the 10 bolt with future plans for a 9". Anyway I bought the Spohn adjustable TA which uses the trans mount location like the stocker. It comes set to neg. 1 degree of pinion angle and comes with a magnetic angle finder and new polyurethane bushing. Once installed I verified the pinion angle and it was right on 1 degree negative. I've had it in for a few days and the car hooks better with no noticable noise. You get a lot for $295. Plus Gordon and Steve are good guys...
--Alan
Nov 18, 2023 07:21 PM
Cam's maro
Mar 24, 2015 08:09 PM
jayvar
Feb 2, 2015 10:00 PM
warmeck
Feb 2, 2015 12:44 AM
mark0006
Dec 25, 2014 09:50 PM
