Skinnies up front.
Old Oct 8, 2004 | 09:33 AM
  #16
WS Sick's Avatar
Re: Skinnies up front.
Also will the longer studd interfere when I put the stock stuff back on ( WS6 rim, stock acorns with black caps)
Old Oct 8, 2004 | 11:11 AM
  #17
Press in, and I think the knurl is "unique" to the 4th Gen at 0.509". You need to check that. You will definitely have problems with the longer studs. Making it even worse it the fact that they include an extra 1/2" of unthreaded length to help guide the wheel on the stud.
This will give you an idea of the magnitude of the problem:
http://cjcfo.fbody.com/members/injun...J/DCP02502.jpg
Old Oct 8, 2004 | 12:38 PM
  #18
Raptor1's Avatar
Originally Posted by WS Sick
Are our factory studs press in?
Yes, and the front ones are relatively easy to replace. Btw, I'm using the ARP studs with 3.5" Weld Draglites and a 5/16" spacer.
Old Oct 8, 2004 | 09:36 PM
  #19
rskrause's Avatar
Moderator
Mine look ok since I cut out the end of the lug nut cap and painted the ends of the studs black.
Rich
Old Oct 8, 2004 | 11:19 PM
  #20
Bills77's Avatar
i agree 100% i drive on the street with weld aluma star 2.0s and the car turns, just not like u'd like it too, be careful around corrners, and turning fast, i've had the car go straight when i've turned the wheel quick, they are really too small for driving on the street, u kinda need a wider tire contact patch, and the car dont stop too good.... flat spotted a few ds-2s
Old Oct 9, 2004 | 03:26 AM
  #21
AL SS590 M6's Avatar
Moderator
If you use the ARP studs putting the stock wheels back on will not be a problem. The longer ARP studs do not have the extra length of non threaded area and fit under my factory caps with the stock wheels on.
Old Oct 12, 2004 | 09:43 AM
  #22
WS Sick's Avatar
Thanks for all the great info guys !!! ARP studs on the way.
RUENUF
Mar 13, 2016 03:37 PM
realistyc
Jul 28, 2015 07:32 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Grover
Wheels and Tires
9
Apr 26, 2004 03:37 PM
stewmeistr
Oct 12, 2002 08:48 AM
