Should I go 4 link?
Old May 13, 2003 | 01:48 AM
slimdawson's Avatar
Should I go 4 link?
Hi. I currently have a Terminator torque arm on my 91 RS. It is mounted to the tunnel with a shaft and cylinder(you can separate the arm from the mount). It makes a little noise during shifts and cruising. It is good for better ets than I will probably see. I plan on mid to high tens. It is just aggravating.
Plus, I am in the market for a 12 bolt. I want to know if somehow the 4 link setup plus the 12 bolt will be better for my goals or should I stick with the torque arm, get a 12 bolt with the arm mount and forget the noise?
Thanks, Mike
Old May 13, 2003 | 08:25 PM
Stephen 87 IROC's Avatar
A good aftermarket 3 link system works well for most people. Installing a 4 link will require back halving the car since the floorboards will need to be cut out for the front mounts. There's just not enough room under the floor to properly install a 4-link.
Old May 14, 2003 | 01:14 AM
slimdawson's Avatar
Ok. I thought it was simple to convert but I guess it is much easier to just stay with a torque arm. I don't have carpet right now and it is just terribly loud inside. I plan on getting some Dynamat and when the new carpet goes in, maybe the noise will be less of a nuisance.
Thanks, Mike
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
karpetcm
Sep 29, 2015 10:08 AM
jayblev95
Sep 26, 2015 09:44 PM
colts0455
Sep 11, 2015 06:16 PM
cmsmith
Aug 9, 2015 07:30 PM
