Removing front swaybar?
#16
If it hooks on the radials, I don't really expect an improvement without the sway bar. It seems to me that a car thats already hooking could actually 60' worse without the sway bar, since power will be lifting the front more instead of pushing the car down the track.
Does this make sense, or am I thinking too much?
#17
Assuming a car is already Dead Hooking, will having excess weight transfer hurt the 60' times?
#18
Your response had absolutely nothing to do with my question. I thought it was a simple enough question, but I will try to rephrase, so as to make it a little easier to understand.
#19
Only if you start dragging the bumper or upsetting(unloading) the chassis AFTER the launch(bad shocks). Even if you're dead hooking, removing the swaybarweight would/could make it more consistant. Everyone dead hooks until the eliminations begin and then oooops....it spun. Bad tracks, etc.
#20
what is the benefit of this? I've heard of ppl removing the front sway bar before, but I don't know nearly enough about suspension to understand why removing something that is supposed to help handling is a good thing? I know as far as drag racing goes your not too worried about body roll cuz ur going straight, but y does that mean it should be removed (weigh a lot? guessing)?
#21
#22
OK, I have had my sway bar off and have daily driven it for years that way...
As far as the benefit, this is of my car's with mostly stock suspension, bolt-on, A4, 3.73 geared car on M/T drag radials...
And no, more weight transfer from removing the bar will not hurt your times, but actually help more...
#23
Sweet. thanks for the info.
How close do you think I am to getting my car too look like that off the line? Getting Nittos in a couple months, and a mail order tune in the next couple of weeks. Assuming I'm capable of a launch like that(probably not, but humor me) would my car be capable? Thats looks badass, and its one of my goals to at least get one tire off the ground someday haha.
#24
#25
Holy crap I never thought of that. What do you need to do to get that to work? How do you do it? I need to know lol.
#26
My point was that until your lift the front tires off the ground the more front lift the better.
#27
These are pictures of my '93. At this time it had a completely stock suspension with the exception of the front sway bar removed. I'm talking stock 94,000 mile shocks, springs, torque arm, lower control arms, etc. Race weight was 3448#. Engine was a 94,000 mile stock bottom end with a little CC305, mildly ported heads, 700 transmission, and leaving at 1500 RPM's. The car would 60 ft. in the mid 1.6X's, and it ran 12.0.
I think it hooked pretty hard for 303 RWHP, and a stock suspension.
Frank
CPT
Frank
CPT
#29
#30
Maybe it's just me, but I'm puzzled as to why that statement would result in such a response from you. I stated nothing for fact, and was basicly asking if I was correct. Oh well, at least there were some people here courteous enough to actually answer a question.
Back on topic. I'll be headed to the track tomorrow night for a little T&T. I'm planning on making a pass or two with the sway bar in place, then removing it. I'll post up the results. Before the flame throwers come out, just let me say that I am not questioning or doupting anyone. I just wanna see exactly what changes in 60' times it makes on my car.
