Reccomendations on 15" rims for drag racing
Old Jul 16, 2006 | 07:30 PM
user 647483's Avatar
I'm looking for a set of rear wheels for my DRs (275mm, will replace with 315s when these die).
I don't want to drive them on the street, just need something for the 1/4mi
Can anyone suggest a good set?
1993 Firehawk with a 2002 Camaro SS rear end and 12" disc brakes.
I'd really prefer not to have to shave my brake calipers if I can avoid it.
I'm more interested in price and function than looks.
Old Jul 17, 2006 | 12:13 AM
AL SS590 M6's Avatar
Moderator
Re: Reccomendations on 15" rims for drag racing
15" wheels and LS1 brakes don't mix without grinding unless you have the big bucks for Bogart wheels.
Might better get some 16x8 stocker wheels and DRs for them.
Old Jul 17, 2006 | 05:42 AM
john35thss's Avatar
Centerline convo pros on my TA and brother in laws SS 15*8.5 15*4 my car 15*7.5 15*4 his. No grinding bolted right on both cars ls1 front brakes lt1 rear but tons of clearance rear.
John
Old Jul 17, 2006 | 08:05 AM
A 315 or 325 drag radial requires a 10" wide wheel.
What is the backspace on the ConvoPro's?
Old Jul 17, 2006 | 02:07 PM
ABA383's Avatar
I had 15x8.5 Convo Pros with a 5" backspace..They did fit, but they hung out a little too far for my taste...Can also look at the Centerline Telstars in the 15x8 with the 5.5 backspace..These supposedly fit without mods and will accept 275 50 R15s...I just sucked up and bought Bogarts and they are absolutely awesome...
--Alan
Old Jul 17, 2006 | 04:48 PM
elisowski's Avatar
15 x 8 Telstars fit. No clearance problems with the inside of the wheels.
They give the car a real muscular look.
But, I had/have problems with the outside of the tires getting cut by the top fenderwell. I pounded the sharp edge up and in against the underside of the fenderwell. Stopped the cuts.
I have QA1 double adjustable shocks and may have had them too soft at the time, but I occassionally see new rubs/burns from the rounded fenderwell even though they are set stiff.
This may not be a problem with stock shocks.
They need an additional 1/2" to 3/4" backspacing to fit perfectly.
I can send pictures if you send me your e-mail address.
Old Jul 17, 2006 | 04:50 PM
Yes please jmontign@yahoo.com
My car is on sportlines (lowered 2.xx"?) and has adjustable shocks (currently set as firm as they go)
Old Jul 17, 2006 | 05:11 PM
elisowski's Avatar
James,
Just sent some photos by e-mail.
Old Jul 17, 2006 | 05:17 PM
James,
Awesome, thanks
9t4lt4z28
Jun 21, 2015 08:18 PM
Flint78
Jun 21, 2015 01:28 PM
james4154
Jun 15, 2015 12:16 PM
Camarokid95
Jun 12, 2015 11:25 PM
Elcojoe
Nov 17, 2014 10:27 PM
