Power Steering removal???
Old Dec 7, 2002 | 08:03 PM
  #16
ru2slo_99's Avatar
My stock bracket was cut so the alternator can fit on the bottom of the engine. I have no idea how good it works because I have not fired the motor up yet. Taking all of that useless, heavy junk out of the way frees up a lot of space to work on the car.
Old Dec 7, 2002 | 08:24 PM
  #17
threadedtire's Avatar
Do you have any pics?
Old Dec 7, 2002 | 10:44 PM
  #18
ru2slo_99's Avatar
Not yet. I will be home from school Thursday and I will go crazy with the camera. I will take pictures of the rack and pinion and the alternator bracket.
Old Dec 8, 2002 | 01:04 AM
  #19
zturbo's Avatar
can see basically where the alt is on pass side low.
Pic on bottom left look at black piece that holds alt
More performance sells the brackets as well.
The rack you just need to take the lines off and get a looped line made, take a bit of the fluid out of the rack as well not much just some.
Steven
Old Dec 8, 2002 | 08:58 AM
  #20
GUMP's Avatar
Dang, that's a bunch of photos!
I really enjoyed them. It looks like a really nice car. When will it be finished?
Daren
Old Dec 8, 2002 | 10:09 AM
  #21
steve10's Avatar
You were taking off your ac correct? Currectly, to place the alternator down low you need to have the ac removed. I manufacture T6061 fabbed kits for this purpose.
I've had on the backburner a design to keep power steering but not ac. I just haven't been able to work on it.
Regarding the power steering. You may want to try running the lines directly to your reservoir. Since the rack is not a self lubricated rack and fluid is pushed from side to side is restricted, if capped off, it may create pressure issues as the interior pressure cannot be equalized when you turn your wheel(although some guys have done it this way and the've said it works fine).
The reason why you can still turn the wheel is the fact you introduced air in the system which you can't bleed out Air is more compressible then the fluid thus you are able to turn your steering wheel. IF you had only fluid in the rack and it was bled, with it capped would make it very difficult to turn if it was capped. This situation will eventually lead to the inner seals leaking.
By running the lines together could be a solution but your not able to bleed the air from your lines with this method. Thus my reason to run lines up to the reservoir. You will be able to run your rack normally while retaining correct pressures in addition to bleeding the air our of your rack which will prolong the life of your rack.
Just some food for thought.
Good luck with all your decisions,
steve10
Old Dec 8, 2002 | 01:12 PM
  #22
PurePonyPounder's Avatar
Can anyone give pics of the power rack crimped/lines looped together. Thanks
Johnny
Old Dec 8, 2002 | 10:48 PM
  #23
mod313's Avatar
An alternative to using the power rack would be to use a Mustang II type manual rack like those sold by Flaming River and others like them.
Old Dec 10, 2002 | 09:11 PM
  #24
chevyguy3's Avatar
its real dirty, and some ill-fitting wires are just zip tied in place since i slapped things together in a hurry to make some runs before the year was over. but anyways heres a couple pics of the motor with the Ac, PS, and accessory drive bracket gone and the Alt relocated
Pic1
Pic2
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
XtremeLt1
Sep 13, 2002 08:50 PM
