Possible stall change, how will it affect me?
Old Jul 26, 2004 | 06:54 PM
formula383's Avatar
I currently have a Vigilante 3200 stall converter and am having the high stall issue and can't seem to get rid of it. I am thinking of dropping the stall down to a 2800. How much do you think it will affect my 1/4 performance naturally aspirated, if any.
I am going to drop this down, which should get rid of the high stall problem and start launching on ET Streets with a 150 shot also, that should help the 60'. So I am not worried about the performance on the bottle.
Old Jul 28, 2004 | 11:14 AM
PoorMan's Avatar
Re: Possible stall change, how will it affect me?
There has been a thread going around that many people have confirmed that adjusting the shift cable by one or two turns has fixed this problem. I have heard that it can be solved in the pcm (kickdown tables??) but I hear mixed reviews on this. Anyway, try an find that thread. It was on ls1tech.com I believe. It is very long and many have confirmed it to work from them.
JD
Old Jul 28, 2004 | 02:11 PM
rskrause's Avatar
Moderator
How's it launch now? If it's spinning itr might be better.
Rich
Old Jul 28, 2004 | 09:11 PM
formula383's Avatar
It does spin on take off, just sometimes it won't shift, when it gets pretty good traction.
I am going a different route now, bigger custom grind cam and it will probably need the 3200, so I guess I will keep working on it.
PoorMan, I will go there and try to find that thread, any idea what it was called? what forum it was in?
Thanks guys
DirtyDaveW
Dec 1, 2016 05:37 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
