I want to run 11s
Old Sep 25, 2012 | 04:20 AM
thunderkyss's Avatar
I want to run 11s
So I quoted this from the fastest LT1s thread.
Originally Posted by taner
FASTEST BOLTON LT1
Tom Cowle
1995 Camaro
Edelbrock Suspension, MT Drag Radials, CSR ewp, Hooker lt's, "junk parts", Mike Blood transmission
1/4:11.702 at 114.30 mph
60 ft:1.55
FASTEST CAM ONLY LT1
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers, Joe O custom grind cam, 1.6rr,Strange 12bolt,QT Pros, Vig3200, 3325lbs
1/4: 11.163 @ 119.86
1/8: 7.05 @ 96.00 1.49 60 ft
FASTEST HEADS/CAM LT1
James Eddy
stock ported heads and intake ,hyd.
1/4: 10.88 @ 122.81
1/8 6.90 @ 99.08
FASTEST 6-SPEED LT1
Taner Bosnali
1996 Camaro SS- Fastest 4th gen LT1 6-speed
399ci LT1, AFR 227cc heads, Nitrous, T-56
¼: 8.97@155.23 MPH
1/4: 10.39@135.71-Naturally Aspirated
According to these times, I can do it with bolt-ons only? I can be sure, & add a cam? I can add a set of heads & roll cage & go deep into the 11s? & stroking the motor would be overkill.... an LSx swap would be more time than it's worth?
I can add a gear in there somewhere as well.
I ask because I'm doing some work to my 96 Z28. It was my primary driver for a while & being overly conservative, I never modded it at all. But now I've got some time to work on it I want to build it up a little. I still need it to be reliable as it'll be my daily driver again soon.
I'm leaning towards the 383, I've always like the way that sounds & if I build it right & learn to drive, I should easily hit my goal of 11 second ETs right? (11.6 to be exact as I have no intentions of putting in a roll cage.
Old Sep 25, 2012 | 04:31 AM
RamAir95TA's Avatar
Re: I want to run 11s
Browse the forums and find a car that runs the numbers you'd like to run, then emulate the setup. That's the most cost-effective way to reach your goals since the research has already been done for you.
Do not assume running 11.70s in bolt-on trim will be easy though. Tom put a **** ton of work into that car.
Old Sep 26, 2012 | 08:45 PM
bw_hunter's Avatar
As Joe indicates, it's harder than it might seem. It gets more difficult the quicker you go. The place to start really isn't under the hood, it's under the car.......suspension is key to solid, repeatable times. Theoretically, you can be in the 11's with less than 400 rear wheel horsepower and you don't need a383 for that...
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jrlt1
Jan 3, 2015 07:38 PM
