New motor won't run
Old Jun 17, 2007 | 06:37 PM
popsicum's Avatar
New motor won't run
Please could somebody tell me what to check next. My new motor is
a stroker, 383 LE 2 heads /w custom cam. I 've checked everything
possible. Timing is dot to dot. 12oclock crank sprocket, 6oclock timing
sprocket. All valves zero lashed. There is a popping coming out of the
intake. Won't idle I was told by my builder that the cam was on point
for the degreed' intake centerline. help Help HELP HELP.............
Old Jun 17, 2007 | 08:12 PM
The Engineer's Avatar
You should post this in the correct engine tech forum. Do you have an LT engine, you haven't said?
WD
Old Jun 17, 2007 | 11:58 PM
He double posted on LT1/LT4 Engine Tech after you posted..... He still hasn't added a signature.
DirtyDaveW
Dec 1, 2016 05:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jessie4tin
Jan 7, 2015 08:53 AM
guionM
14
Jun 19, 2002 08:30 AM
