Need major lowering after weight reduction????????
Old Apr 28, 2008 | 11:05 AM
STOCKTA's Avatar
1994 TA Started out at 3680# when I bought it 6+ years ago, did the usual fiberglass hood, carpet insulation!,, stereo!, spare!, oil cooler, etc, etc. Last year weighed in at 3340# with half tank, pulled swaybar and 1/4tank it should be at 3300#. Started major weight reduction plan last week and managed to pull 226# more out of her. All interior except door panels, dash, console, and two racing buckets are all thats left inside. Pulled AC/heater, condensor, all tubing and HVAC box, put in delete plate. Relocated battery, washer fluid bottle!, ABS!, pulled dash ripped out all un-needed insulation heater vents and motor. This should put her at 3300-226=3070's# shooting for 3000# when finished. After all of this the car looks like it ready to go 4-wheeling, the gap between the tires and fender well are about 6"-7". What have you major weight reduction guys done to bring it back to stock ride height? Ive been inspired by shon herron and john P. to do this to my car since its mainly a toy and I love the times there running all bolton.
Old Apr 28, 2008 | 02:34 PM
MEAN LT1's Avatar
Some adjustable coilovers have your name on it.
Old Apr 28, 2008 | 02:46 PM
SNOTGREEN's Avatar
On the cheap, perhaps v6 springs?
I haven't used coil overs or adjustables up front in my car yet, and it isn't quite as light as yours just yet either, but that or similar may be my plan after getting rid of a couple more things up front and will probably be looking at the same problem you're having right now. Anybody?
Old Apr 28, 2008 | 04:38 PM
tomcowle's Avatar
I have cut down 6 cyl springs in the rear of my car, the car has a nice stance with a 28" tall MT Et Street radial tire.
The car did "raise" itself this winter after my weight reductions too.
Old Apr 28, 2008 | 04:43 PM
STOCKTA's Avatar
V6 Springs sounded good when it weighed 3300's, Anyone ever cut down the stock springs safely? I need a picture of it, everyone ask if its on a floor jack and they cant believe its so goof ball looking.
Old Apr 28, 2008 | 04:48 PM
STOCKTA's Avatar
Tom, your car and John P's, Shon Herron are my inspriration for this madness. I have pulled every thing except the crash supports and foam sides. I will have to check on some V6 springs from the local scrap yard.
Old Apr 28, 2008 | 04:50 PM
tomcowle's Avatar
If your looking for v6 front springs let me know, I just switched to front coilovers and mine are just laying on the shop floor.
Old Apr 28, 2008 | 04:51 PM
STOCKTA's Avatar
Also its at least 1"1/2-2" taller wheel gap in the front, Even when I stand on ithe front (200lbs) it dosnt even flinch.
Old Apr 28, 2008 | 04:53 PM
STOCKTA's Avatar
already cut? PM me for price. Thanks
Old Apr 29, 2008 | 11:05 AM
STOCKTA's Avatar
14" from nose to floor
4" gap in between front tire and fender well.
More crap I gutted out
Me weighing out crap
Old Apr 29, 2008 | 12:18 PM
96' Formula WS6's Avatar
that fender gap looks like my friends 96 when we pulled the motor out.
Old Apr 29, 2008 | 12:20 PM
STOCKTA's Avatar
Funny thing is my buddy came in and thought it was on a floor jack until I told him what I did.
Old Apr 29, 2008 | 04:55 PM
Couple problems here....
1. Please do not post anything but "engine" questions on "LT1/LT4 Engine Tech".
2. Post only in one forum. You already have this on Drag Racing.
Thanks.
I can merge the two threads in Drag Racing, or move them to "Suspension, Chassis and Brakes". What is your preference?
Old Apr 29, 2008 | 05:02 PM
tomcowle's Avatar
I have true duals on my car that exit right before the rear axle, its tough to get the car as low as I want to on both ends. I run a 26" tall front tire on the front and a 28" tall tire on the back. I still street drive my car from time to time and I need to watch for bottoming out the tailpipes.
I had roughly those same "clearance issues" you had in the rear at first, however thru the magic of the cutoff wheel I got it to my liking.
Old Apr 29, 2008 | 08:11 PM
STOCKTA's Avatar
Ok, didnt know that. Go ahead and merge into Dragracing.
