Local Indiana track TNT results
Old May 12, 2007 | 07:07 AM
MichiganSkip's Avatar
Well, Here's the progress, or lack of, after the LT's(w/full exhaust), Double adjustable LCA's, New Hal rears set at 6, and tweaking the AFR in PE mode for 4400-6000rpm. (running right at 12.7-12.6)
1.96 13.666 at 100.88mph
2.00 13.559 at 101.10mph
1.99 13.660 at 100.94mph
2.16 13.846 at 101.10mph
2.05 13.563 at 101.34mph
2.04 13.617 at 101.36mph
2.21 13.849 at 101.42mph
Last year's last TNT after installing the 4.10's
1.87 13.896 at 96.79mph
1.87 13.929 at 96.52mph
1.89 13.914 at 96.58mph
2.01 14.050 at 96.57mph
1.99 13.971 at 97.24mph
I wonder what I'd have done if I could have gotten some traction. Looks like the changes really helped the mph.The track got pretty greasy after the first few runs yesterday, seemed like everyone was saying they couldn't get any traction after about the first hour.
stock 95Z LT1 A4 4.10's
Old May 13, 2007 | 08:40 AM
AL SS590 M6's Avatar
Moderator
Boy that's a great improvement in ET and MPH and all with crappy 60s. Get that to hook and you'll be bottom 13s easy.
Old May 14, 2007 | 01:59 PM
DMcRacer's Avatar
It looks like you picked up about 3 tenths and 3 and a half mph with about the same 60ft. It will be interesting to see what happens when you get it to hook.
The only changes you made under the hood are long tubes and adjusting the FPR ?
Old May 14, 2007 | 05:20 PM
Long Tubes and adjusting the PCM in PE mode. It still has the stock regulator on it. I went into the computer and took out some fuel in the PE table.
Old May 14, 2007 | 07:29 PM
2000GTP's Avatar
Nice improvement. A converter and some good tires and you'll be the lower half of 13s easy.
DirtyDaveW
Dec 1, 2016 05:37 PM
TitoPR221
May 26, 2015 12:20 AM
Z28Freak86
Apr 28, 2015 10:35 PM
Brady
Jul 29, 2002 10:30 PM
