linelock
Old Mar 6, 2008 | 08:46 PM
axehead's Avatar
linelock
i'm thinking of getting one to make burnouts easier at the track with my 6 speed. what is a good one? is it ok to have one on a street car?
Old Mar 6, 2008 | 10:36 PM
Sure. As an added safety, install a master power switch with a pilot light, that prevents activating the line lock with its push-button, unless the master switch is armed. I have a Hurst, but there are many other good ones, mostly cheaper than the Hurst. Pre-bent lines are available, making the install a lot easier.
Old Mar 7, 2008 | 12:09 AM
Stephen 87 IROC's Avatar
If you're not hung up with cosmetics, Biondo is a favorite among racers.
You'll never notice it with street use. Your brakes will work like normal. You use a momentary switch to activate it so you'll never accidentally turn it on and leave it on.
To use, it's plumbed into the front brakes only. You step on the brakes, sometimes pumping to build more pressure then push the line lock button and release the brakes. The line lock holds the pressure in the front brakes allowing you to do a burnout with no rear brake pressure. When the linelock is released, the front brakes release.
On the street, the car would never know there's a linelock installed even if you push the button while driving since there's no brake pressure to hold and as soon as you release the button, the lock releases.
Old Mar 7, 2008 | 07:53 AM
A problem I've seen with my own line lock... a short locked the solenoid, even when the momentary wasn't pushed. Fortunately, it happened when I was trying to take the car off the trailer, so no big deal. Using the master arm switch completely prevents that from happening.
Old Mar 7, 2008 | 01:26 PM
The Engineer's Avatar
SLP makes a really nice custom-fit line-lock w/ pre-bent lines for 4th Gen F-bodies. I changed the kit supplied toggle switch to a trans-brake type push-botton (momentary switch).
WD
Old Mar 20, 2008 | 02:59 PM
Shon Herron's Avatar
SJM's kit is very nice. They have just a LL kit with either the Biondo or Hurst LL and can be had with or without ABS delete.
If you would like a quote let me know.
Old May 18, 2008 | 10:53 AM
axehead's Avatar
a fellow at jeg's said i might need 2 line-locs, what is he talking about?
Old May 18, 2008 | 12:03 PM
For "most" NHRA No-Electronics (No-E) classes the line-lock can only be used for the burn-out and "not" to launch the car. Same for a trans-brake in No-E, it can't be used.
Maybe the guy a Jeg's was thinking front wheels for the burn-out and all wheel line-lock for the launch. Again, that isn't allowed in the No-E classes.
WD
Old May 18, 2008 | 04:13 PM
That makes no sense....
Old May 19, 2008 | 04:36 PM
axehead's Avatar
yes, i would like a quote please. thx
chevydriverlt1
Mar 6, 2010 03:54 PM
97TransAm
Middle Atlantic
10
Jul 28, 2007 01:42 PM
sp33d33ss
May 12, 2007 09:34 AM
Tims2001z
Parts Wanted
Mar 26, 2007 10:41 AM
