HAL/QA1 shock problem, HELP!
Old Feb 10, 2004 | 02:46 PM
HungryT/A's Avatar
Red face HAL/QA1 shock problem, HELP!
Ok, I'm a bit sad at the moment.
I've just got my complete HAL shock package, and on one of the front shocks the adjuster **** seems to be not working!
On the #1 setting, and even on #12, the shock can be compressed really easy... The other shock is dead firm at setting #4!
Please help, what should I do? I heard somewhere, you can readjust it in some way or what...
Old Feb 10, 2004 | 05:55 PM
nd4spd200's Avatar
Have you banged the *** on anything or something like that?? You may have to send the shock out and have it rebuilt.. If so i could recomend a good place to have it rebuilt.. PM me if you have any questions... Later
Old Feb 10, 2004 | 05:58 PM
HungryT/A's Avatar
No, it wasn't working right out of the box...
I was extremely easy on the ****, I heard you must not overtighten them...
Old Feb 11, 2004 | 11:34 AM
Fastbird93's Avatar
Screw sending it out for a rebuild, send it back and get a replacement.
Old Feb 11, 2004 | 07:59 PM
nd4spd200's Avatar
True if it wasn't workin right out of the box send it back and get another... You didn't say in the post it was brand new.......
Old Feb 12, 2004 | 01:11 PM
HungryT/A's Avatar
Thanks guys,
Thunder Racing got in touch with QA1, I hope they'll send me a replacement...
And yes, it was brand new, right out of the box, as I said earlier.
Thanks again!
Old Feb 15, 2004 | 12:03 AM
IllusionalTA's Avatar
That happens when you turn it too far to the right.. as if you were tightening it.. there are only 12 settings.. the bottom setting to the left is 1.. and count the next one as 2 so on and so forth.. for safe measure always go back to 1 prior to adjusting to a higher setting to further prevent going to far w/ the ****.. just some info figured might be beneficial..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
siguy
Nov 27, 2014 10:07 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
slothgrant
Aug 22, 2002 03:01 PM
