Guys who have done a th350/400 swap..please come in.
Old May 15, 2003 | 02:20 AM
  #31
Daddyo's Avatar
Yeah Chris' single is sweet looking. But I too am going with a double. I might not need a bar at all. With just the anti roll bar I should leave alot straighter. Last year I was all over the place, looked like a 4x4 leaving the line.
Old May 15, 2003 | 03:49 PM
  #32
zturbo's Avatar
With the anti roll bar you should be set then if leaving square is the problem. Hopefully i will have some pictures of launches with mine all done in the next few weeks.
Old May 16, 2003 | 02:41 AM
  #33
GhostZ's Avatar
Originally posted by Injuneer
B&M Pro-Ratchet in a 94 M6 console.
Install
Console
The boot has a snap on the top (open in that pic), so I can take it off at the track, and see the gear selector indicator......
Damn nice setup!
Old May 16, 2003 | 03:03 AM
  #34
Daddyo's Avatar
"Hopefully i will have some pictures of launches with mine all done in the next few weeks." That would be sweet
.Yeah my whole problem was launching like a 4x4 to much body roll. My 60 foots were 1.90's with et streets is sad. We will see what happens this year.
Old Jun 16, 2003 | 08:12 PM
  #35
93 Indy's Avatar
Originally posted by chevyguy3
To make the speedometer work on a 4th gen with a TH400, you need to use an A4 pcm file, and GM/AC Delco part #s 8655315 (rotor) and 8655291 (sensor)
Will this work for a 93?
Old Jun 16, 2003 | 11:25 PM
  #36
zturbo's Avatar
Does the speedo on the 93 have elctronic or manual? If electronic you are set. If not then you will just use a manual setup.
Steven
Old Jun 17, 2003 | 07:35 AM
  #37
NCTURBOS's Avatar
Steven
zturbo,
I'm helping 93 Indy out with his car. It's was non-electronic 700r-4 and now has a TH400 in it. What is it he needs to do the "manual setup"??
Is there a GM part#(s) he can use??
TIA,
K.
Old Jun 17, 2003 | 07:42 AM
  #38
Shon Herron's Avatar
TIA,
K.
the trans is "manual" but the speedo is electronic, with the TH400 the part numbers are listed in this thread. Another option is the Dakota DIg stuff like I have but depending on what parts you get from them, you might need to be able to burn some chips to get the speedo right or with the convertor box i have it is a dip switch set up, and that is the costly part of the DD set up...looking back after this thread, i just needed the $30 part since I have LT1 Edit...oh well...
Old Jun 17, 2003 | 11:19 PM
  #39
REPO's Avatar
So does anyone else have this A4 file that has been mentioned in this thread??
I asked the first guy, but he doesn't have it anymore.
Email me at REPO@shaw.ca
cmdeshon
Dec 27, 2014 10:06 AM
Snoman73
Nov 17, 2014 07:22 PM
94z28jbw
Sep 8, 2002 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
