First trip to strip w/ ta writeup
Old Jul 23, 2006 | 12:12 AM
pHEnomIC's Avatar
Well All in all, I was a bit bummed on my e/t and 60's but I was really impressed on my trap speed. I have all the details in here.
02 t/a, 6speed, 3.42, firehawk rims, pirelli street tires 35psi all around, lts, ory, dynomouth, lid, bellows, ported tb, !spare, !emissions, !some interior panels and rear seats, !frontswaybar, !stb.
LCA,s, phb, SLP Bilsteins, Eibach prokit, 1le rear swaybar.
I consider myself a pretty good stick driver but I never had track practice. I had my lt1 z/28 a4 at the same track last year and did a 13.9 @ 101
High of 76 degrees.
This is the 2nd time at the track, 1st time with my 6speed. Here's the story:
Drove 1 hour to the track, right away run w/ no preperation and run my best e/t of the day 13.4 @ 108.29 (2.159 60'). I watched an incar vid and i hit the limiter twice (possibly in neutral) but i wasn't powershifting. I launched easy w/o revving up.
I had a few crappy runs and had to bail once because my clutch slipped. I then had a few good runs averaging 13.5 -13.6 @ 108 - 109. Most of the 60' were 2.2 - 2.3.
My last run I ran 13.5 @ 110.75. I was delighted w/ this trap speed. I launched at 2200, modulated a decent launch and powershifted every gear.
My car feels like its just revving in neutral once i get the tires spinning and i can spin through 1st, 2nd, and some of 3rd easy. I had to be careful not to break em loose or the run was shot. I noticed though that even w/ a good launch, this car was a lot more squirly than my z, it is all over the place.
I really would like to shave off some 60' times and get my car into the 12s.
I generally shifted just under redline and quick precise shifts. At first i launched w/o revving but later i worked myself up to about 2200 and modulated the clutch and gas to minimize spinning. I noticed that at wot shifts right under redline the rpms fluctuate which may mean the clutch is going. My clutch may be on its way out as well but it still has some life.
I didn't try any runs shifting any lower, but should i possibly try shifting lower?
My tires are almost shot so i may be picking out some drag radials. Anything I should try technique wise next time i go? Do you think 12s are possible with my setup and how would i achieve them?
Old Jul 23, 2006 | 06:10 AM
SFB767's Avatar
Re: First trip to strip w/ ta writeup
With a very strong trap speed like that, your car is already telling you it's 12-sec. capable, you just need some drag radials and a little more practice.
Old Jul 23, 2006 | 08:27 AM
AL SS590 M6's Avatar
Moderator
What track were you at?
Buddy has a 98 formy that traps 109s and still can't get into the 12s (13.002). It's very tricky with the stick shift. And even with a drag radial and 4.10s it will take good weather, good track conditions and some good driving. As he just found out when he put the DRs on with the 4.10s and broke the gearset.
Old Jul 23, 2006 | 11:18 AM
pHEnomIC's Avatar
I've been going to lapeer dragway in michigan. Not exactly known for for good track prep. I was thinking that could be some of it.
Old Jul 24, 2006 | 07:38 AM
Moderator
Being that you go to Lapeer be very aware that it's trap speeds are generous. We've had many dissapointed folks that used Lapeer traps to base judgement calls on that were very dissapointed when they went to Milan, Martin, Stanton, or out on the street.
Not saying that your car doesn't run good or anything like that. Just saying when you get a chance take it to a real track and see how it does.
Old Jul 24, 2006 | 01:44 PM
pHEnomIC's Avatar
I will keep that in mind but most people said their e/ts and traps were on the low side that day compared to their usual bests.
It is a bit of a confusing time for me because I need tires. I want to get drag radials but i don't want to pop the rear (can't buy a 9in or 12bolt atm and i dont want to rebuild the 10bolt). But then again, wasting power through spinning isn't cool either.
Old Jul 25, 2006 | 12:45 AM
Moderator
If you can't afford a HD rear then it's better to waste power than have your car parked because the rear is broken.
Come on out to Stanton Saturday for the Street Tire Shootout and see what it'll do on a good track and hang out with us.
68camaroboltz
Oct 5, 2015 11:56 PM
pepon214tx
Sep 20, 2015 04:48 PM
Daluchman1974
Sep 11, 2015 06:12 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Campbellb48
Jul 5, 2015 06:31 PM
