et improvements from stall and pro trans
Old Mar 13, 2008 | 07:16 PM
slowride94z's Avatar
I think my trans is belly up, wondering what kind of improvement I can expect from 3000 ish stall and race trans?
Old Mar 14, 2008 | 08:23 AM
AL SS590 M6's Avatar
Moderator
You might be able to squeak into the 12s on a really good day.
Old Mar 14, 2008 | 07:34 PM
o come on I was hoping to get 12s with what I had . was planning to go tonight until this
Old Mar 15, 2008 | 06:23 AM
Moderator
Until you do you haven't.
I was going off your sig. If a 13.4 is the best that you've done and haven't changed anything, how did you expect to run 4 tenths quicker?
Old Mar 15, 2008 | 07:31 AM
mdacton's Avatar
Converter might do it....If he could get in the 1.85 60' range it would do it. As long as it didn't run out of breath
Old Mar 15, 2008 | 08:47 AM
the 13.41 was after a 1 hour drive down there and no cool down strait off the street, I wanted to get that run in before friends showed up you know I had no idea what it would run.
I'm not making excuses I was very happy with this run normally aspirated.
buy running out of breath do you mean heads? cam?
I'm guessing with a converter the street tires are toast, and have to get some street slicks.
I've already got a 1.91 60' and a 12.88 with a little spray
still got 90 hp to go
Ive added relocation brackets and new springs since.
https://www.camaroz28.com/forums/showthread.php?t=579250
Old Mar 16, 2008 | 08:06 AM
godspeed1976's Avatar
You should hit 12s no problem with stall and DRs.
Old Mar 16, 2008 | 08:18 AM
mdacton's Avatar
you need a sticky tire
Old Mar 16, 2008 | 09:03 AM
what do you mean about running out of breath?
thanks I'm thinking about slicks after trans
Old Mar 16, 2008 | 10:06 AM
mdacton's Avatar
I mean your just cruising...not gaining any speed/making any power up top.
Cam/heads etc........
Whats your MPH in the 1/8 and the 1/4?
Old Mar 16, 2008 | 11:12 AM
81 and 102 normally aspirated car hot
http://www.youtube.com/watch?v=DMBeFqsLsv8
found this on ls1tech YEA thats me 13.013 @107.34 w 1.936@60'
vett 11.548@124.44 W 1.88@60'
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
