E.T. street questions
Old Jan 5, 2004 | 09:43 PM
95 Mystic TA's Avatar
Question E.T. street questions
I currently have a few bolt-ons, built tranny with 3000 stall, 373's and a NX wet kit spraying 100. I won't be spraying out of the hole but I'd like to know how my rear end is going to hold up with a set of 16" E.T. streets. I have ran Nitto's and although I like them alot on the street, I can't hook at all on any of the tracks I have been to. I've tried expirementing with different P.S.I.'s and launch techniques with no prevail. I have an extra set of 5 star silver wheels to mount the E.T. streets on.
Questions 1
What size do you guys recommend for a 16" wheel?
Question 2
Again, not spraying out of the hole, how well will my rear hold up? Should I worry about breaking it with my mods?
Thanks for the help.
Old Jan 6, 2004 | 07:41 AM
rskrause's Avatar
Moderator
26x11.5x16 works well on stock rims. You will definitely get more traction than with DR. I have a stiff suspension (1LE parts, not drag friendly) and run low 1.5 sec 60' times on a good track. Rear end? Anyone's guess.
Rich Krause
Old Jan 6, 2004 | 10:12 AM
Deenasty's Avatar
run et streets at around 17psi, make sure to do a good burnout, right were the water meets the dry pavement. make sure to drive around the water box, and back up in it. I will tell you, if you have a stock 10 bolt, that is history!!
Old Jan 6, 2004 | 11:34 AM
Raptor1's Avatar
You're right about the burnout. Although if you have skinnies on the front it's not really necessary to drive around the water box.
As for the stock 10 bolt, it depends on what kind of shape it's in to start with and how well the gears were set up when they were installed. I have 4.10's and had 670 passes on mine and a lot of street abuse before I took 4 teeth out of the ring gear
I know guys running mid 11's with stock rear ends without premature failure. But they are all auto's. Guys with M6's break them all the time.
Just my $0.02
Old Jan 6, 2004 | 11:40 AM
Deenasty's Avatar
exactly right about the skinnies. I had 4:10's in my m6, and had about 30 runs, some street abuse, and BOOM!! Twice! Had to go Moser...
Old Jan 7, 2004 | 01:09 PM
Thanks for the replies. My rear was set up by a very experienced installer so hopefully I'll get some a few passes before it goes. Thanks again.
Old Jan 8, 2004 | 07:04 PM
funina91ss's Avatar
I have a thrown together 10 bolt with 3.23, solid spacer,and girdle and it holds up to 1.54 60ft times and 11.11 1/4 mile times shotting for 10's with the stock bottem end , stock rebuilt trans(no aftermaket parts) and 10 bolt. Spring time should do it..
Old Jan 11, 2004 | 03:31 AM
96redformula7's Avatar
So with my 10-bolt, AUTOMATIC, and my mods in sig...I should be fine with et streets?
Old Jan 11, 2004 | 08:49 AM
funina91ss's Avatar
RUENUF
Mar 13, 2016 03:39 PM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Brady
Jul 29, 2002 10:30 PM
