Which drag wheels?
Old Nov 20, 2003 | 12:19 PM
  #16
Raptor1's Avatar
If you're only going to put them on the front and for drag race use only, Weld Draglite 15" x 3.5" with 1.75" back spacing and 5/16" spacers will work without grinding the calipers. You will need longer studs to be safe. I use ARP 12mm x 1.5", part number 100-7708 through Summit.
Old Nov 20, 2003 | 07:24 PM
  #17
kevkop94TA's Avatar
Yeah I'd be using them for drag only. I mean it would be ok to drive on them to and from the track though, right? As long as I don't drive like a maniac?
Old Nov 21, 2003 | 06:46 AM
  #18
Raptor1's Avatar
As long as the road is relatively straight and smooth These rims bend easy, so hiting a pot hole, or even rough road, while going around a corner can ruin them. That's why Weld specifically states, "FOR DRAG RACE USE ONLY".
Old Nov 21, 2003 | 11:14 PM
  #19
JWINN's Avatar
I run these frt runners and street use is a big plus with me.
www.gofastzone.com/members/The_KING/016_25a.jpg
Old Nov 22, 2003 | 09:12 PM
  #20
revtime's Avatar
I agree not to use Front runners on the street they will break going around a corner and trash your car.
XPs are heavier than regular pro stars but they are still lighter than my salad shooter / bridgestone combo.
Old Nov 24, 2003 | 03:00 PM
  #21
mongse_1's Avatar
I drove a set of Convo Pro fronts from St. Louis to Memphis before. If you've ever travelled I-55 down to Memphis, it's not the smoothest road ever made.
JWINN, even I'd be hesitant about running those on the streets and I run Bogarts. They kinda look like Welds, but I can't place them. I know I've seen them before.
Old Nov 24, 2003 | 07:21 PM
  #22
kevkop94TA's Avatar
So it wasn't too bad then? Its not bad going to my track. 90% of the ride is down the garden state parkway. I don't think it'd be too bad on them.
Old Nov 25, 2003 | 02:15 AM
  #23
Kain's Avatar
I've got the other Centerline wheel, the Telstar. I daily drive them in the summer. For an LT1 car, they're direct fit. No spacers, no grinding. LS1's you've got to do some caliper grinding.
Old Nov 25, 2003 | 11:40 AM
  #24
JWINN's Avatar
You girls must drive your car's on some of the worst streets in the United States! I have drove these wheels on public roads for some time with no problems. Now if your doing corners like a formula one car or hiting pot holes then no explanation would be required why you have bent wheels.
I had a drag car with spindle mount frt wheel and I drove this on the street for years without tacoing then if I hit a small bump and if anyone has ever seen a spindle mount rim it is even lighter then the rim I currently have in the pic. A rim that is for drag race use only is the legal disclaimer for the retards that want to use the rim as they would as there OEM rim, beating the **** out of it.
Be carefull with a drag wheel on the street and you will not have any problems but if you are a young senseless kid that wants a drag wheel that has the strength of a road race wheel,4X4 wheel and so on then nothing will hold up for you. I would suggest buying circle track steel rims because at $50.00 or less a rim you then can afford to act like a retard with them.
Advice to live by,
Jim
Lets RACE!!!
Old Nov 25, 2003 | 01:52 PM
  #25
mongse_1's Avatar
You definitely haven’t seen the wonderful work MODOT and IDOT does on the highways.
I had no problems w/ my Convo Pros. The car actually ran better in the rain w/ the skinnies than w/ a wide tire.
Old Nov 25, 2003 | 02:01 PM
  #26
JWINN's Avatar
Are you kidding me I live in Michigan. You know snow,snow plows,bad roads. Just drive with sense and never drive slicks in the rain.
Good advice to follow!
Jim
Old Nov 25, 2003 | 04:02 PM
  #27
Cody's Avatar
I have centerline warriors 15x10's on the back and 15x4.5 on the front and I didnt have to grind the calipers
Old Nov 25, 2003 | 05:58 PM
  #28
Brady's Avatar
yep, lots of street miles there...
I bet I've got 20,000 miles on my prostars and I've never bent a wheel. just don't drive like an idiot and you'll be fine.
Old Nov 26, 2003 | 09:50 AM
  #29
mongse_1's Avatar
Jim
Preachin to the choir man. I’ve been running skinnies for the last 3 years and never bent a wheel. My Convo Pros were perfectly round and my Bogarts had no problem w/ a country road @ 50mph.
Old Nov 26, 2003 | 09:36 PM
  #30
JWINN's Avatar
Attention to detail is always good to have when your trying to see what kind of car the other guy had! New car new rims and tires.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BMX Dad
Wheels and Tires
Apr 26, 2015 11:36 PM
Moshbmx1
Jan 20, 2015 03:27 PM
TitoPR221
Jan 2, 2015 03:51 PM
