Which drag wheels?
If you're only going to put them on the front and for drag race use only, Weld Draglite 15" x 3.5" with 1.75" back spacing and 5/16" spacers will work without grinding the calipers. You will need longer studs to be safe. I use ARP 12mm x 1.5", part number 100-7708 through Summit.
Originally posted by kevkop94TA
Yeah I'd be using them for drag only. I mean it would be ok to drive on them to and from the track though, right? As long as I don't drive like a maniac?
These rims bend easy, so hiting a pot hole, or even rough road, while going around a corner can ruin them. That's why Weld specifically states, "FOR DRAG RACE USE ONLY".
I run these frt runners and street use is a big plus with me.
www.gofastzone.com/members/The_KING/016_25a.jpg
I agree not to use Front runners on the street they will break going around a corner and trash your car.
XPs are heavier than regular pro stars but they are still lighter than my salad shooter / bridgestone combo.
I drove a set of Convo Pro fronts from St. Louis to Memphis before. If you've ever travelled I-55 down to Memphis, it's not the smoothest road ever made.
JWINN, even I'd be hesitant about running those on the streets and I run Bogarts.
They kinda look like Welds, but I can't place them. I know I've seen them before.
You girls must drive your car's on some of the worst streets in the United States! I have drove these wheels on public roads for some time with no problems. Now if your doing corners like a formula one car or hiting pot holes then no explanation would be required why you have bent wheels.
I had a drag car with spindle mount frt wheel and I drove this on the street for years without tacoing then if I hit a small bump and if anyone has ever seen a spindle mount rim it is even lighter then the rim I currently have in the pic. A rim that is for drag race use only is the legal disclaimer for the retards that want to use the rim as they would as there OEM rim, beating the **** out of it.
Be carefull with a drag wheel on the street and you will not have any problems but if you are a young senseless kid that wants a drag wheel that has the strength of a road race wheel,4X4 wheel and so on then nothing will hold up for you. I would suggest buying circle track steel rims because at $50.00 or less a rim you then can afford to act like a retard with them.
Advice to live by,
Jim
Lets RACE!!!
Advice to live by,
Jim
Lets RACE!!!
You definitely haven’t seen the wonderful work MODOT and IDOT does on the highways.
I had no problems w/ my Convo Pros. The car actually ran better in the rain w/ the skinnies than w/ a wide tire.
Good advice to follow!
Jim
yep, lots of street miles there...
I bet I've got 20,000 miles on my prostars and I've never bent a wheel. just don't drive like an idiot and you'll be fine.
Originally posted by JWINN
Are you kidding me I live in Michigan. You know snow,snow plows,bad roads. Just drive with sense and never drive slicks in the rain.
Jim
Jim
Moshbmx1
Jan 20, 2015 03:27 PM
