dissapointed track times!
Old May 8, 2004 | 03:34 AM
ram air camaro's Avatar
Unhappy dissapointed track times!
hi fellas, i'm finally saying good bye to the street's, here are my time slip at the 1/4 mile strip. i need help something is wrong?
1 of 3
my best time of the night:
R/T .553
60' 2.100
330 5.922
1/8 9.001
mph 80.76
1000 11.628
1/4 13.840
mph 102.19
dude's something is wrong ! my car felt like i hit the rev limiter or a missfire or something because i had to let go of the gas and floor it again to get to shift i think it's my dam tranny!
my car is a 94 z28 camaro a-4.
Old May 8, 2004 | 07:12 AM
'94 Bad A Z28's Avatar
I would say tranny.... sux. I am on my 4th BUILT tranny, so this is the 5th trany in my car, in 4 years.
Old May 8, 2004 | 12:03 PM
i think my car should be performing at high 12's.
I WAS reviewing the video and it sounded like 1-2 shift are hitting rev limiter now! before it was just a 2-3 shift.
do you think maybe it's the opti not the tranny since my water pump is covered of oil ?. dam i'm just pissed off! i feel burning that car.
Old May 12, 2004 | 11:52 PM
MarkyMark's Avatar
Go
your 60 foot is really bad too with your mods. Tonight I ran a 2.098 60 foot with 2.73 gears, a4, street tires, cai, and exhaust cutout.....so im basically stock. What I found worked the best is just slowly accelerate and then floor it right when your to the point where you wont break the tires loose.
________
Depakote class action lawsuit
Old May 13, 2004 | 12:47 AM
i'm going back this friday. and will be hoping for an improvement since i just did wire's and plugs a few hour's ago and found a wire boot toasted i be driving it tomorrow to see if it run's good but now i have another problem i broke a vacum line that comes from a canister under the front pasenger side right under the battery. and i belive is causing a engine light and rough idle.
Old May 13, 2004 | 06:47 AM
Sounds like you broke the line off the vacuum reservoir for the heat/AC system controls. No biggie.... pull the hose off the passenger side of the intake manifold and put a vacuum cap on the manifold nipple..... at least until you can repair the line.
Old May 13, 2004 | 05:00 PM
maroon94z's Avatar
Also, make sure your shift points and rev limiter are set correctly. My car did exactly what you're describing when I first got it, because the previous owner never took the time to set the PCM for the 3.73 gears.
Bill
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
