Need help shifting =(
Old May 9, 2004 | 08:51 PM
sirgreg23's Avatar
i have a 2000 ram air m6 and ive been having trouble at the track missing 4th gear.....i talked to a guy drivin a 01 with an m6 and he said not to even shift into 4th at all.... is he right or what ..... can anyone help me hit 4th gear .... i dont understand why i miss it .... i never miss it on the street .... i guess its just nerves ...heres my very dissapoiting track times without 4th gear
im getting very frustrated
2.3 60ft
9.1 quarter at 81mph
14.6 quarter at 79 mph and without 4th ... can someone help me =(
Old May 9, 2004 | 10:04 PM
JoeliusZ28's Avatar
http://www.camaross.com/forums/showt...hreadid=259390
Im having a similar problem... its really making me angry, cause I really dont like seeing my tach read over 5500rpm. Im just like you, Ill never miss a gear if im just cruising, but as soon as I do a WOT blast I miss a gear probably 40% of the time. Im half blaming my shifter though, since I never had a problem with my stock unit.
Are you dropping to second like me on the 3-4?
I realize that all I should have to do is pull the shifter back for the 3-4 shift, but somehow it still falls into second sometimes
Old May 10, 2004 | 12:03 AM
sirgreg23's Avatar
yeah thats exactly whats happening ......... ive even practiced getting on it on the street and i never miss the 3rd to 4th ...but as soon as i get to the track i missed it both runs .......someone suggested to turn my palm in towards 4th gear soo if i miss i go into 6th instead ...... has anyone tried that yet ... does it work i really am getting frustrated .... i know i shouldnt give up but it sucks
Old May 10, 2004 | 04:39 AM
AL SS590 M6's Avatar
Moderator
Do that and make sure that your elbow is off of you side so that your arm is parallel to the console and parallel to the floor. That way when you pull back you don't try to pull it towards you.
Old May 10, 2004 | 05:09 AM
Tair's Avatar
Yea, you definitely should sit in your normal position for WOT runs and then notice the placement of your elbow. Although this sounds stupid, you probably just have nerves that are making you subconsciously pull the shifter straight at you.
Old May 10, 2004 | 10:08 AM
5.0eater's Avatar
When i shift hard i place my hand at the bottom of the shifter to make sure that i have a good grip on it and that hass helped me alot from missing second and fourth try that it may help.
Old May 10, 2004 | 04:30 PM
joeSS97's Avatar
You might want to get an aftermarket shifter.A lot of people like the Pro 5.0.I have the Hurst,which I like.B&M Ripper is another.
Old May 10, 2004 | 04:37 PM
sirgreg23's Avatar
yeah i think your right Tair .... this was my first time to ever race a standard at all ...... i think it was just nerves or something to that effect ......those are all good suggestions and i think it should work ..... i will hit 4th gear next time hopefully putting me somewhere in the 13s (13.8 and ill be happy lol ) then i can work on it from there ..... someone suggested running around 22 pounds of air in my street tires to lower my 60 foot .. and i feel like my cutout is killing me on the low end ... of course i havent seen how much it helps on the top end really cause i havent made it into 4th yet lol
thanks guys ..any other suggestions will be appreciated
Old May 10, 2004 | 08:28 PM
1BAD80-Z's Avatar
You're getting too excited !! ( Been there !! ) Take it easy and granny shift it until you get used to it !! A slow 4th gear is better than NO 4th gear !!
Old May 11, 2004 | 12:48 PM
Ron78Z&01SS's Avatar
It may sound kind of wierd, but try the 3-4 shift with your hand upside down.
After the 2-3 shift, turn your hand so that your pinky is at the top of the shifter handle, your index finger at the bottom....your knuckles are facing you and your palm is facing the passenger's side. When you shift pull the shifter back, 3-4 and you'll be A LOT less likely to hit 2nd.
Give it a shot, it may work for you.
Old May 13, 2004 | 09:45 PM
MikeyG's Avatar
Get a short stick/shifter of some kind. It makes a world of difference. Two trips to the track ago I made 4 passes and missed a total of 3 gears (one run I missed 2nd and 4th on the same run, retarded, huh?). I installed a short stick a couple of weeks later and went back to the track. I made 5 passes and missed no gears at all. The stock stick is GARBAGE!
Oh, and you're nervous, too. That was part of my problem as well.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
