chasing those pesky 9's
Old Sep 15, 2003 | 08:34 PM
Rob@combination's Avatar
im the owner of combintaions '01 ss. new best with the combination motorsports heads/cam combo. 10.48 @ 129.3 with a 1.49 60'[200 shot on stock bottom end]. the heads are cnc stage 2(with the new spring design). the cam is quite large at 236/238 and over .600 lift on both intake and exhaust. right now we are having issues with the tranny and converter. the converter in there now is the same one i had when i was running the 4.56 gears. so its flashing a little high on the juice(5800 rpm's). plans are in the works for a 400 with a brake and a vig converter. hoping to get it to the 9's might be a little optimistic, but we are confident we can get pretty damn close. and even though nitrous makes its own air, the da was 4900 feet on that run. video of that run should be up in the next day or 2.
Old Sep 15, 2003 | 11:26 PM
Stephen 87 IROC's Avatar
You'll probably slow down with the TH400. It's heavier and takes more HP to turn. Consider using a TH200c (metric 200) or a powerglide instead.
The TH400 weighs 130 pounds and uses 44hp. The powerglide weighs 97 pounds and uses 18hp. The Metric 200 is almost identical in performance to the powerglide except it has an extra gear.
Old Sep 16, 2003 | 01:51 AM
97bowtie's Avatar
I'd expect a little more MPH out of a h/c LS1 spraying a 200 hit. Good numbers none the less.
Old Sep 16, 2003 | 02:27 AM
Drew778/94Z's Avatar
I just want 10's
Good luck Rob, I'm sure you get if you don't run out of nitrous first GEEZE
What is that 1 bottle a run
What about a Stage 3 4L60E?
Good Luck
Andrew
Old Sep 16, 2003 | 05:39 AM
Nostang 96z's Avatar
Converter slip will kill mph.
Great numbers and I'm sure you'll get 9's once you get everything dialed in and the tranny swapped out. BTW any NA times? Are you spraying through a single fogger?
Later
Matt
Old Sep 16, 2003 | 12:51 PM
without sounding like im making excuses, there was also about a 15 mph head wind. but like stated, converter slip will kill mph. as far as n/a times.....11.81 @ 115 with a very crapy 1.68 60'(again, converter issues) on the same night as the 10.48. which means the da was 4900'. about the tranny.....i already have a power robbing 9" in the car, so im not scared of the 400
Z Power
Sep 19, 2015 11:19 PM
Scorch1
Jun 30, 2015 11:24 PM
OutlawPerforman
Jun 15, 2015 12:49 AM
MattFick
Feb 15, 2015 10:16 PM
Alex Barnes
Jan 24, 2015 10:21 PM
