60ft vs. ET
Old Sep 12, 2006 | 01:14 PM
BarneyMobile's Avatar
60ft vs. ET
I kno one of the most inportant part of the race is the first 60ft so I wanna kno how much of my ET can I shave off if can go 1.6 60ft. My best was a 1.8 on street tire. Soon I'm getting some dr's, adj t/a, boxed lca's and some QA1's.
To date my best run is
60' .... 1.805
330 ... 5.151
1/8 ... 7.922
MPH .. 86.77
1000 . 10.391
1/4 ... 12.462
MPH .. 110.79
So how much faster will my ET be if I go 1.6 60ft?
Old Sep 12, 2006 | 06:51 PM
The Engineer's Avatar
Re: 60ft vs. ET
At a minimum, your 1/4 mile ET should be in the 12.20s if you can shave 2 tenths off your 60ft times!
http://www.cardomain.com/ride/2189634
Old Sep 12, 2006 | 09:21 PM
Dave '97 Z28 M6's Avatar
Re: 60ft vs. ET
I've heard it mentioned as a bench racer's quick-and-dirty calculation that for every tenth you improve at the short end, you often see 1.5 tenths at the big end of the track. This is obviously not a certainty, but might apply to your situation.
Old Sep 13, 2006 | 11:16 AM
rje's Avatar
rje
Re: 60ft vs. ET
I'd say you would probably run in the 12.1's easily with a 1.60 60ft.
Randy
Old Sep 13, 2006 | 05:48 PM
CamaroRacing12's Avatar
Re: 60ft vs. ET
i dn but nice times either way
Old Sep 14, 2006 | 09:54 AM
Z-RATED94's Avatar
Re: 60ft vs. ET
.32 faster. Really tho it's hard to say. As mentioned before, about .15 quicker in the quarter for avery .10 you cut off your 60ft. At least thats a close assumption for cars about as quick as ours.
Old Sep 20, 2006 | 01:50 PM
Capn Pete's Avatar
Re: 60ft vs. ET
I've typically heard as a quick "rule of thumb" 1 tenth in the 60' is worth 2 tenths 1/4 mile?
But .15 is probably closer to "realistic" .
Actually, if you look at the times in my sig, I ran 13.434 w/ 2.152 60', then 13.021 w/1.942 60' time. If you work it out, that's 1.967 tenths improvement in the 1/4 for each tenth 60' . That's almost 2:1!!
Old Sep 21, 2006 | 09:25 AM
JakeRobb's Avatar
Super Moderator
Re: 60ft vs. ET
You pulled a 1.8 60' on street tires? That's amazing.
I want details. What car? What tires (make, model, size)? Race weight? Air temp? Track elevation? A4 or M6? What converter/clutch are you using? What's your launch technique?
A lot of questions, I know. But that's a really phenomenal number for street tires.
Old Sep 21, 2006 | 12:08 PM
myslowcamaro's Avatar
Re: 60ft vs. ET
i wonder what my time would be then with a better tc. im cutting 2.07 (best 60' times but landing 11.87@ 118 on dr's. hope to have cpt redo the tranny and install a fuddle soon.
Old Sep 21, 2006 | 12:15 PM
rskrause's Avatar
Moderator
Re: 60ft vs. ET
It depends on why the 60' increased. If it was just due to better traction, the gain will close to 1:1. But if the gain is due to more power, there may be a much larger improvement.
Rich
Old Sep 22, 2006 | 01:09 PM
Re: 60ft vs. ET
Rich
Good to know!
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
NewsBot
Jul 3, 2015 02:10 PM
