60'
Old Jan 23, 2008 | 09:30 PM
  #16
Razor_Blade's Avatar
Originally Posted by northdakota93z28
thanks for the info. it will be a few months before the tracks open and i am very excited. what is your best time??
My best 1/8 mile pass is an 8.12 @ 83 on a 1.700 60' time. I didn't have a helmet so I wasn't able to make any full passes that night. My best ever 1/4 mile time was a 13.53 @ 61 mph..LOL. That was from rolling out of it at the 1/8 mile and coasting through the 1/4. I'm hoping for mid twelves next time out.
Old Jan 24, 2008 | 03:21 AM
  #17
Airbornec507's Avatar
I've made numerous 1.6xx 60' times on the stock 10 bolt 3.73 gears/girdle/eaton posi with a 3000 stall on M/T DR and salad shooters. The last time I ran before I sold the ten bolt was a 1.589. It still held up fine on the drive home. I upgraded to the 12 bolt before I blew the 10 bolt and sold it relatively cheap for what I had into it.
Old Jan 24, 2008 | 09:06 AM
  #18
Z-RATED94's Avatar
So what brand converter is it?
Old Jan 24, 2008 | 12:15 PM
  #19
CamaroRacing12's Avatar
im hoping to cut some low 1.7's with stock suspension 3400 raceweight and a 3400 vig converter and 255/50/16 et street radials
Old Jan 24, 2008 | 04:08 PM
  #20
northdakota93z28's Avatar
cool, my first time out i will post it on u tube and we will c what she will do
tci stall
Old Jan 24, 2008 | 04:13 PM
  #21
elevation has so much to do with times not 60foot so much but at 4000 feet i ran a 9.8 all motor with no mods and the same thing at 2000 feet ran 9.4 both 2.3 60' doing some bench racing i hope i can pull 1.7 60s and run a 8.7 all motor!! i hope
Old Jan 25, 2008 | 09:25 PM
  #22
wow that elevation suxxxxxx my track is only at like 80ft above sea level
Old Jan 25, 2008 | 10:11 PM
  #23
it is huge, you can have a 12.5 second car at sea level bring to my 4000 feet and never pull better than a 13.4 (that is a na car)
Old Jan 26, 2008 | 07:31 AM
  #24
AL SS590 M6's Avatar
Moderator
Our tracks here in MI are all around 700' but we're surronded by lakes and the DA during the summer is usually around 2500-3300'.
Old Jan 26, 2008 | 11:58 AM
  #25
epping NH New England Dragway
80ft above sea level and racing until october 40 degree racing 0 DA's
Old Feb 10, 2008 | 01:58 AM
  #26
canuck94z28's Avatar
Track time
Since your probably very close to Minot you need to make some runs there and find out for sure b/c the track does separate the b from the s (lol) and the alt. there is under 2,000 ft. Also my buddy has a 96z vert and even w/3.42,2800 vig stall,nittos, and some susp.mods can only do a 2.03 60ft.at our local track so any camaro that does a 1.8/1.7 60 ft. esp.w/stk susp.has to have lots of mods!The alt.at our track is 1600 ft. and my car w/less gear,no stall,less weight,than buddies couldn,t do under 2.0,and b/f i bought my mt et streets the mt tire rep.said i might do 1.95,so either there,s something screwy w/my car or just maybe it,s a lot harder to run these no,s than it looks.
Old Feb 10, 2008 | 02:36 PM
  #27
or maybe the track prep blows? lol
Old Feb 14, 2008 | 02:36 AM
  #28
Track prep,etc.
Good point and a further point is that our local track is volunteer run and doesn,t even have concrete on starting line.I have to travel 150 mii.to the track and i,m glad there is one at all.
Old Mar 20, 2008 | 04:44 PM
  #29
96ws6medina's Avatar
I hit a 1.84 sixty foot in my T/A at least 50 times last season launch on a 65 shot without anything more than a WOT switch.
Everything else on the car was stock besides bfgs, i didnt even have any of the exhaust done much less any aftermarket suspension. You should be fine as far as the 1.7-1.8 sixty time.
But with your mods i would imagine more of a 1.6 sixty AT LEAST if the track and altitude is good. If not i would go elsewhere to run my times.
Old Apr 18, 2008 | 04:43 PM
  #30
just got my dr on, i took it out on the street and warmed them up and they did not spin at all. so that is good, when i get to the track i will post my 60' and see what it will do
